General questions as I tear my truck apart
I'm tearing my 70 K10 apart and creating the list of what needs to be replaced....
1. The wiring harness looks like a rats nest. Can anyone give me a picture of a fuse block? Has anyone used the EZWiring harness? What are your comments on it? 2. Where does a stock washer reservoir go, mine is missing and they are in different locations in pics posted on other threads. 3. Where does the radiator overflow mount? I have a antifreeze bottle chicken wired to the grill. 4. The sticker on the glovebox door says my truck came with A/C and now it doesn't have it anymore and there is a patch over the firewall hole. Can anyone give me some good pics of how everything should look (locations of parts inside cab and engine compartment)? Thanks in advance for any help you can give me! |
Re: General questions as I tear my truck apart
To answer #1, use the Painless kit. It is well laid out and is about as "painless" as you can get and still be realistic.
#3 | |
![]() Join Date: Mar 2006
As far as the other questions the only advice I can give is to buy a factory assembly manual and start marking pages. GL with the teardown!
1986 C10 - LWB, 305/700r4, posi, vortec heads |
If you are going stock I would use a M&H harness.It is made to exact factory blue prints and plugs right in with no cutting. If you order it they will modify it for HEI and internally regulated altenator. All of the board supporting vendors should be able to get it. Chris
washer jug goes on the driver side inner fender toward the front
didnt come with coolant recovery system/just a rubber hose that spit on the ground// i believe there was a dealer install option tho for tha ac unit pics and stuff i'd suggest getting the factory assembly manual most vendors on here carry it or it's available on ebay
Here are a bunch of A\C threads with pics or diagrams:
http://67-72chevytrucks.com/vboard/s...threadid=66112 http://67-72chevytrucks.com/vboard/s...threadid=92889 http://67-72chevytrucks.com/vboard/s...threadid=58584 http://67-72chevytrucks.com/vboard/s...vacuum+diagram
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
i used the painless kit in my 68 swb and it went in easy and works great and comes with everythinh for every option.
Thanks for the input everyone.
cdowns, I saw a pic of the washer bottle location in another thread so I can use that as a reference. neonlarry, I've seen the diagrams, I am looking for actual color pics of stock and aftermarket units. I took some at Hot August Nights last summer but my memory card took a dump on me and I lost them all. Most engine compartment pics are focused on the top of the engine so it's hard to see what the a/c equipment looks like. If anyone has pics that they can email me or post, I would appreciate it. Chris |
Eat My Rust
This weekend Ill get pics of the A/C unit in my '69. Its about the only thing I have under the hood, lol.
THE VILLIAGE IDIOT
you mean the anti freeze jug is not the factory over flow jug...i dont think i ever saw a truck this old with anything else...
honestly honey,,i have no idea how that truck got here. ![]() |
I have some other hoses and parts that I have no idea what they are for. I'll take some pics this weekend and try to post
