Old 01-10-2007, 06:26 PM   #1
manimal
manimal's Avatar
84 M/C to 69 C10
Will a 1984 suburban 1/2t 2wd master cylinder and booster bolt to my 69 c10? I am going to buy front rotors this weekend for 6 lug and I am going to use the sub's spindles and calipers and prop valve.But didnt know if I could use the rest?!?!Thanks
-Lance
manimal is offline   Reply With Quote
Old 01-10-2007, 09:57 PM   #2
qksilver
Re: 84 M/C to 69 C10
have to drill a couple of different spaced holes in the M/C bracket and cut a slice off where the columm bracket interfers. Plus have to make/weld a new pedal push rod to fit between the M/C and the brake pedal. Last but not least besides the rerouting the brake lines is to drill a hole about 1 1/4 inches down from the manual hole on the brake pedal arm and use that for the power brake rod
qksilver is offline   Reply With Quote
