View Poll Results: Should I go with the 383/TH350 or 454/TH400 | |||
383/TH350 | 20 | 29.85% | |
454/TH400 | 43 | 64.18% | |
Don't Care! | 4 | 5.97% | |
Voters: 67. You may not vote on this poll |
01-10-2007, 07:56 PM | #1 |
Broken Down
Engine Choice 383/TH350 or 454/TH400
I am rebuilding my 383 stroker but have a family member who has offered me a 454 and TH400 from a old 86 winabego RV camper. All I have to do is pull it out and rebuild it. Should I stay with my 383 or should I go ahead and fork a little extra cash and build the 454?
kenm78 1982 Chevy 4X4 Project truck “It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt” |
01-10-2007, 08:04 PM | #2 |
Re: Engine Choice 383/TH350 or 454/TH400
the 383 is a better choice because it is cheaper to rebuild and you can make easy power w' it. but i would pull the th400 and use that if it fits, because it is stronger
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
01-10-2007, 08:04 PM | #3 |
Id vote for the big block but its your choice, not mine. I say go get it anyway, even if you dont put it in its a good combo to have around...
01-10-2007, 08:16 PM | #4 |
Fabricate till you "puke"
That 383 is a runner for sure, I have one in my old truck. I will say one thing for sure tho.....if you dont give a chit about mileage, a well prepped BB will run soooooo much harder than the 383! I did run a 461 inch Olds in my old chev, & will say it was the "nutz" ! The only thing that Olds could not pass on the open road was a freakin gas pump! Its your "nickel".....spend it how you like, & have fun L
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-10-2007, 08:51 PM | #5 |
motor selection is entirely based on what the application is. Lots of pulling, a big block is good. Strokers are awesome but its harder to get low rpm torgue from them like a big block. For a daily driver they rock.
01-10-2007, 09:14 PM | #6 |
THE VILLIAGE IDIOT
personaly i say the big block....but i got a 454 in my 84,,and i wouldnt get rid of it for nothing,,well maybe a 572,,but for pulling, hauling if i can get it on a trailer or in the truck i can take it with me...and is great for coming out of big hole with a load,,or that might be because of the granny tranny to..never had a stroker motor so couldnt say,,but i think strokers are more to say you got one..not trying to start anything with the stroker guys...
honestly honey,,i have no idea how that truck got here. |
01-10-2007, 09:38 PM | #7 |
Weekend Warrior
I say get teh 454/400 anyway just to have it around. If you're already into the 383 keep going and finish it. If you have to start fresh with the 454 build - it will be more $$ out of your pocket.
save the 454 for your next truck
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered |
01-10-2007, 09:56 PM | #8 |
Parts and more parts
"There is no replacement for displacement" HOWEVER, if you have a lack of funds, the 454 will enhance that when it comes to purchasing parts. Once built, it will last a long time and pull hard, when needed.
I have a 383 and I love it, however it is a small block and has it's limitations. It is easy to work on and it is a high rev motor, in comparison to a BB, but the HP of the 454 will beat it in the long run. |
01-10-2007, 09:59 PM | #9 |
Well, Whoop-dee-do!
If longetivity & how many miles you can clock before needing a rebuild again is taken into consideration, the 454 will last longer IMO. If they were both built to similar power levels, the 383 will need more go fast parts of course, & will work harder if you use it. FYI, every 454 motorhome engine I have been into from that era was a 4 bolt main.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD '72 K20 500 Cad/TH400/NP205 SOLD '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car |
01-10-2007, 10:30 PM | #10 |
Broken Down
anyone know what year gm started using roller cams in there 454s
01-10-2007, 10:59 PM | #11 |
Well, Whoop-dee-do!
I believe it was 1996. That's what the cam was made for I used in my '88. Also required the cam retainer & timing set for a 96 also. I Used a Comp "96-up replacement grind" cam with retrofit lifters. Comp's tech line said I would have to drill holes in my block for the retainer and that the OEM threaded holes wouldn't line up- total BS. It all went together with no mods.
01-10-2007, 11:07 PM | #12 |
One thing to consider when (if) rebuilding the Winnie's 454....
If it's got heads with the infamous "peanut ports", they won't flow worth a flip. Plan during your rebuild to swap to some decent 781 castings or similar. Otherwise, above 3000 RPMs or so, your 454 will be sucking air through a straw, loose all it's real HP potential and worse, the 383 in your neighbor's truck you could have had will drive circles around you. Breathing is everything for a BBC. Keep the TH400 though. You'll need it regardless of which power plant you choose.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe |
01-11-2007, 12:00 AM | #13 |
Well, Whoop-dee-do!
My '88 454 is mainly a driver & occasionally a trailer puller. It had the huge chambered low compression peanut port heads originally. I parted out an '88 454 propane power unit engine & used the heads off of it. I can't remember the casting number, and mortec didn't list them. They have smaller valves (but not as small as the propane heads of the 70's) and smaller combustion chambers than my OE heads, but large ports & stellite exhaust valves with hardened seat inserts. I used a Performer TBI peanut port intake. I know it may seem silly to have small runners going into large ports, but the runner dumps high into the port, which I think lets it flow past the short radius easier while keeping velocity up for the lower rpm range this engine lives in. The setup works for me- it picks up faster and pulls stronger with 3.21 gears than it did stock with 4.10's. I have another TBI unit to mess with, I'm going to send it off to have it opened up & bigger throttle plates installed. Curious to see how much that will gain.
01-11-2007, 07:51 AM | #14 | |
You do bring up a valuable point though. And that's to try to achieve a 3-way match between the purpose of the vehicle (towing, daily driving/street/strip), the torque and HP curves of the engine once it's built, and the normal or average operating RPM. In your case it seems your engine's torque curve and operating RPMs are now closely matched, which takes us back to the question about 383 or 454. My guess is the 383 would be the better choice if the gearing is numerically higher, and 454 if the gearing is numerically lower. Food for thought.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 01-11-2007 at 07:52 AM. |
01-11-2007, 11:16 AM | #15 |
Member #1049
IMHO.. the only substitute for a Big Block is a bigger one!!
01-11-2007, 12:06 PM | #16 |
The Older Generation
I have a 454/th400 in the white truck.... I don't know why, but when I go for a ride in that thing I never want to go home. It's a hoot to drive..... When I'm driving that truck I feel about 20 years younger than I am. (that still makes me an old fart though).... LockDoc
01-11-2007, 12:50 PM | #17 |
454 / t400 is an awesome combo , the best . In my opinion our trucks look better with a bbc filling up the engine bay , they cost a little more but there worth it . 383's in a Nova or Camaro , big block in 4000lb trucks , just my .02 .
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
01-11-2007, 10:18 PM | #18 |
I couldn't agree more.
01-11-2007, 10:36 PM | #19 | |
Well, Whoop-dee-do!
I could pull the motor & tranny out of either one of my trucks and still weigh more than that
01-11-2007, 10:41 PM | #20 |
Truck Enthusiast
i love my setup with the 454/400 and 4.11's in the ass. roll 45mph and light em up
'85 swb Last edited by droppedgmc; 01-11-2007 at 10:42 PM. |
01-11-2007, 10:53 PM | #21 |
Well, Whoop-dee-do!
I swapped the gears before the rebuild, so I have experienced just the engine improvement alone. I'm sure it would really scoot if I put the 4.10's back in. But I agree, even though it has alot more upper rpm power than the stock motor did, the real grunt is made down low now. I'd love to have a Gear Vendors overdrive, even with the 3.21's. It would be great for hwy cruising. I think there is enough grunt that it would pull a 6-7K trailer load in OD with ease, except in the hills of course. Drive for small hills, high side of second for moderate hills & 2nd for the nasty climbs. There isn't much for hills around here that are nasty though.
01-12-2007, 06:27 PM | #22 |
Broken Down
How do I tell if they are the peanut heads??? any pictures of a peanut head and non peanut head.(we are talking about cylinder heads keep your minds out of the gutter) LOL
01-12-2007, 07:26 PM | #23 | |
In Memoriam...
No pics here of the "peanut" heads, but I believe casting # was...346236. Started production in 1975.
'68 C10 SWB 307ci 2BBL FarmTruk Pics Here "You know, doing what is right is easy. The problem is knowing what is right." |
01-12-2007, 07:53 PM | #24 | |
Love it!!!
01-12-2007, 08:01 PM | #25 | |
Underlining is mine And "ignitionman" in a post at www.Chevelles.com says "IgnitionManApr 30th, 00, 11:49 PM At this point, I think we should all get to agree with the port terminology of BB cylinder heads. All dimensions are darn close if not right on, it's from memory. Rectangle is 2.125" tall x 1.240" wide, Oval is 1.900" tall x 1.065" wide, Square (peanut) is 1.065" tall x 1.065 wide. All refer to intake port configuration, not plug thread/jacket types used. Rectangle and oval were used from production inception in 1965 to 1974, then the only BBs were in trucks, and went to square (peanut) port heads, all of them past 1975. No peanut intake port heads were used or produced before 1975. Large truck 366 and 427 tall deck engines all used Oval port heads, all years, all pickup 454's changed to square (peanut) port in 1975." Hope it helps you ID your heads.
69 C-10 SWB Fleetside 454/TH400 (For Sale) http://67-72chevytrucks.com/vboard/c...ct=1299&cat=12 70 El Camino 454 TH700 29 Model A 4-DR Sedan Deluxe Last edited by mnunn454; 01-12-2007 at 08:09 PM. Reason: Add'l info found, plus formatting |
