K10 Help
Hye guys, i am new to the board and i need help. I have a 67 K-10 with a
70's 305, 4-speed, dana 44 front, 12 bolt rr and i have no idea what transfer case is in it. I am planning to do a mild (4") Skyjacker lift w/ 35" tires. It has really rusty floors, the bed (longbed) is a metal floor and the floor and sides are completely rusted out. I haven't found any companies that supply the longbed panels or floor. I would appreciate any help in finding parts from companies or personal experience. Thanks, Ed
'67 C20, Under the Knife!, LWB, Eaton HO-52, Rear Coil Springs 72' GMC C2500, 350, TH400(?), Dana 60 '67 K10 4-spd., 305, SM465, Dana 44, 12 Bolt, RUST! '65 C60 292, 4 spd, 2 spd Rearend, 15' Grain Box, MINT! 09 Yukon Denali 82k Miles 6.2L/6A |
Re: K10 Help
You will just need to look for a decent longbed as no panels are being reproduced besides the front piece.As for the lift...67-68s are harder to get a lift kit for because the springs are different.Good luck on getting one
THE VILLIAGE IDIOT
Re: K10 Help
last night i was looking through the vendors section here,,and somebody had bed floor panels..not sure on bed side...i forget which one,,but man they got alot of good stuff on the vendors on here
honestly honey,,i have no idea how that truck got here. ![]() |
Post Whore
![]() Join Date: Feb 2000
Re: K10 Help
Can you get a pic of your transfer case? It should be a Rockwell T221 if stock, but someone could have swapped that out of course.
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
Re: K10 Help
ok, is there a way to tell by looking at it?
Re: K10 Help
Top pic is of the NP205 t case out of my 71 4x4.
The bottom 2 are of the rockwell T221 out of my 69 4x4 Hope this helps. |
