![]() Join Date: Aug 2001
1/2 ton to 2 ton - cabs the same?
is there any difference between the 60-63 10 - 30 cabs and cabs for the 60-63 40 - 60?
Professional Beer Tester
Re: 1/2 ton to 2 ton - cabs the same?
Yes, the 10-30 cabs are basically the same as the C40-C80 trucks. The main difference is the front fenders and the grill shell-radiator support. The doors, hood and cab will swap. Some of the bigger trucks may have a different bolt-in floor hump depending on what transmission it came with. I think the outriggers are in the same place on 60-63 pickups and big trucks, but on the 64-66 trucks the outrigger locations are different between pickups and big trucks.
There were also the "L" series big trucks known as the low cab forward trucks which looked very similar, but the hood is shorter and the doors are different. 64 L60 65 C80
60 Ford F100 Custom Cab 61 Apache Short Fleetside 64 C10 Short Stepside 65 C80 409 V8 5spd(X-Firetruck) 83 GMC 350 Olds Diesel 85 GMC Short Bed 86 GMC Short Bed 90 GMC R3500 Crew Cab 92 GMC 1500 |
