01-11-2007, 06:29 AM | #1 |
68 gmc vin decode
can some one please help with this vin/i checked every where even here and no vin decode:ce20dza15312
01-11-2007, 06:37 AM | #2 |
THE VILLIAGE IDIOT
Re: 68 gmc vin decode
there is a vin decoder on the front page,,but let me take a crack at it
ce20dza15312 C= 4x2 E = V-8 Gas 2 = 3/4 Ton ?????? not sure on this one ok im lost,,there is a vin dcoder on front page,, for some reason im not matching up the numbers or you need to check to make sure you got the right number...the rest of the guys can help out more maybe
honestly honey,,i have no idea how that truck got here. |
01-11-2007, 10:30 AM | #3 |
That's funy.That's my VIN except a few numbers off at the end.I don't remember the exact decode means except what he said above plus it's a fleetside made in Freemont Calif. Also,mine is a '69.Only the last serial # is different so I think you have a '69 model,possibly made in last '68.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
01-11-2007, 12:06 PM | #4 |
its all about the +6 inches
GMC doesn't decode like a chevy, and on top of that, they differ from year to year. They even had diferent codes within model years.
Hopefully Rod will get this. |
01-11-2007, 03:00 PM | #5 |
THE VILLIAGE IDIOT
well glad to know they decode diff..thought i was going blind trying to use the vin decoder..kept switching back and forth,,and nothing matched after the 3rd number..
01-11-2007, 11:41 PM | #6 |
ce20dza15312
C = conventioanl cab E = Eight cylinder 2 = 3/4 ton OD = Fleetside box Z = Fremont Assembly Plant A = 1969 15312 is sequence number of vin uzz gots yourselves a 69 look at the style of steeeing wheel and note location and direction of the fuse box block...typical easy ways to see differences between 68 and 69 send the california rust free cab my way...thanks.
Senior active founding member. 70 3/4 ton GMC Suburban 4x4 250/4 spd. 71 1/2 ton Suburban Chevy 4x4, 350/350 72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane 2005 FLSTSCI Harley Springer 85 FXSB Harley Lowrider 72 Triumph 650 Bonneville 5spd "Poor people don't have hobbies" Quote from wife. Last edited by Rod; 01-11-2007 at 11:46 PM. |
