Old 01-11-2007, 09:39 AM   #1
BudTX
BudTX's Avatar
Blown Fuses
My son's 1983 K20 keeps blowing the fuse to the tail lights. When I replace the fuse and turn the lights on with the engine off, the tail lights are very dim. If I start the truck and then turn the tail lights on, the fuse blows. It takes a 20 amp blade fuse. I tried a 25 amp (I know, I know), but it still blew.
Any ideas? I know next to nothing about troubleshooting electrical problems (except that you don't put a fuse with a higher rating in when you short one out ).
Thanks,
Bud
Current GM toys: 1983 Chevrolet K20 4x4, 2004.5 Chevrolet 2500HD LT Duramax 4x4
BudTX is offline   Reply With Quote
Old 01-11-2007, 01:15 PM   #2
us111
Re: Blown Fuses
hello,,that certainly sounds like a pinched wire somewhere,about the only way to find it is take the tail light apart and start checking wires all the way from there to fuse box or until you find it..most likely gonna be a bare wire somewhere...
us111 is offline   Reply With Quote
Old 01-11-2007, 01:20 PM   #3
Russell
Professional Grade
Russell's Avatar
Re: Blown Fuses
Also make sure that your ground is still good. Its located behind the tail light on the driver's side.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-11-2007, 01:36 PM   #4
BudTX
BudTX's Avatar
Re: Blown Fuses
Thanks!!
Old 01-11-2007, 06:31 PM   #5
wedgemon
wedgemon's Avatar
Re: Blown Fuses
Remove one bulb first - then test (have spare fuses). If that doesn't blow. You've narrowed the search by half.
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 01-11-2007, 08:32 PM   #6
75silverstep
KEEP ON TRUCKIN.
75silverstep's Avatar
Re: Blown Fuses
I had a similar problem .Mine was the taillights also but when i would turn them on they would blow and then my dome light would come on ya i dont know..well i found that behind my fuse box the conections were coming loose or they were off couldnt tell when i pulled it of the firewall ..
1975 C-10 STEPSIDE (ALMOST DONE AGAIN)90 percent done wheres that other 10 haha .1994 GMC Z71 .
75silverstep is offline   Reply With Quote
Old 01-11-2007, 11:36 PM   #7
j hannah
comfortably numb
j hannah's Avatar
Re: Blown Fuses
when you are tracing wires, use a circuit breaker instead of a fuse. itll save you from buying a bunch of fuses.
1974 gmc 3/4 t. c/s
1974 chevy k-10
1973 pontiac grandville(turnpike cruiser)
j hannah is offline   Reply With Quote
