Old 01-11-2007, 06:34 PM   #1
stsalvage
Scrapper 1
stsalvage's Avatar
1965 3/4 Ton 350 With Pg Full Power
Where Secont Owner On This Truck Truck Blong To Sun Kiss Orange Company In Hemet Calif It Came Factory With 283 Power Glide With A 456 Rear Gear It Had Power Asist Steering No Power Brake/
Now It Has 350 With Same Power Glide Has The 411 Gear Cus I Broke 3 Teeth Of Rear Gear So Swaped It For A Used 411 It Has All New Bushings Has A 1978 3/3 Ton Suburban Disc Brakes With Sub Frame As Wull Replumed All New Brake Lines Changed Over To Power Brake And Power Steering On The Fram From Same Suburban Allnew Wireing From Factory Replacement Has Hei Uses The Same Ram Horns Run 16 Inch Rims Not 16.5 Run A 235/85/16 Inch Tire For Hualing And To Change The Gear To A Higher Gear So I Can Run At 70 With Out Over Reving The Eng New Heater Core And Man Dose It Get Hot And New Radiator Kepted This Truck As Factory As I Could But With The Safty Up Grades For Pulling And Hualing Scrap Metal
Used This Truck For 18 Years It Has Never Left Me On The Side Of The Road It Had A Welded On Hitch With Brake Controler As Well Here Are The Pics
stsalvage is offline   Reply With Quote
Old 01-11-2007, 06:42 PM   #2
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
Re: 1965 3/4 Ton 350 With Pg Full Power
nice old truck,,well you could put it into early retirement and rebuild it...
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 01-11-2007, 07:48 PM   #3
stsalvage
Scrapper 1
stsalvage's Avatar
The Frame Ribbits Are Shiffting Cus Of All The Havy Loads I Hualed In It Need A New Frame But Will Be Transfered To 1/2 Statice
