simple question: dome light
i keep burning bulbs every few days, maybe up the fuse size a little?
Re: simple question: dome light
Are you talking about you keep blowing the fuse or the bulb? If it is the fuse keeps blowing check for a short along the sill plate, they like to ground out there. If it is the bulb keeps buring out quickly. No help. You could have got a bad batch of bulbs.
Ya, Like Aaron said, the fuse doesn't make any difference. Maybe they are not a bad bunch, just the wrong type for your application.
04 4x4 GMC Ext. Cab lifted 71 2wd GMC / Ramjet 350 ready for sheet metal 49 Studebaker pickup |
Are they 6 volt bulbs? No clue if they would blow, just an idea...
I just took a look at mine and it works! I've had this truck for over a year and I had no idea there was even a bulb in there. I turned it on be accident
Well, Whoop-dee-do!
![]() Join Date: Mar 2003
I'm almost certain you have a poor ground. High resistance in a ground circuit will do it every time, same is true for any light bulb. Do you have door jamb switches? they are the most likely culprit. If no jamb switches, only the headlight switch turns them on, I think the ground for that circuit is a wire with an eyelet grounded under the dash somewhere. Maybe someone else on here can chime in exactly where it is. Poor cab to battery groundpath could do it too.
'68 GMC shortbox 4x4 350/SM465/T221- bought it in '83 SOLD ![]() '72 K20 500 Cad/TH400/NP205 SOLD ![]() '92 Chevy 2500 6.5 mech TD 4L80E crusty daily driver '72 Monte Carlo... sweet low mile toy '11 Dodge Challenger IE 392 6spd... midlife car ![]() |
#7 | |
blood type; Retumbo
I agree with most of the other comments. Lot's of good things to check. Just DON'T increase the size of the fuse. The fuse is sized for the wire used. To big a fuse and a short down the line could result in a melted wiring harness or worse.
Enjoying life again. Time to get those big blocks rolling. |
sufficiently talented fool
![]() Join Date: Jun 2006
A poor or loose ground that is intermittantly making a connection could be causing a rapid fluctuation in current flow, which could lead to rapid bulb failure. I think I would try a different bulb first. Make sure it is a 12v bulb, and get a different brand. If it still does it, check and clean your door jamb switches.
Bob
"it's impossible to be surrounded by idiots when you are part of the circle" ![]() 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
well after putting a new bulb in, the headlight switch and door jamb switches activate it. the fuse is good. the bulb will be burned within a copule days. i'm not sure on the bulb, the part # is what's mentioned in the book, and the last bulb came from a ford f150 my friend has.
