01-12-2007, 08:39 PM | #1 | |
FI computer tuning anyone?
Ive been slowly throwing parts at the BBC sitting in my garage until the one in my truck finally dies and I can throw in the meaner motor.
Is anybody here really into FI, so into that they know how to program chips/proms? I managed to "aqquire" a used gear drive for only $40. Since im going TBI with my new motor I cant run it because the when the teeth on the gears mesh the knock sensor will see that and mistake it for knock and tell the prom to pull timing. Thats bad... So for those of you who might be computer savvy....is there a way to desensetize the knock sensor so I can run one? Thanks, Mitch-
01-12-2007, 09:17 PM | #2 | |
Re: FI computer tuning anyone?
Disconnect it. Sorry couldn't help myself. Are you sure that the knock sensor will pick the gear drive up as pinging?
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
01-13-2007, 12:31 AM | #3 |
This is what i have heard also but not exactly sure how to get around it since this is the way i am going too. I know we will be taking mine to a guy in Tulsa to program the pcm to not look for stuff like egr and run a 454 pod and injectors. Not exactly sure how he is going around the pinging but will ask my buddy and get back to you.
2008 Ford FX2 Screw 1971 C10 project in shop now! 2004 Pontiac Grandam (wifes) 2000 Cavalier z24 (gas saver) |
01-14-2007, 03:32 AM | #4 | ||
01-15-2007, 09:05 PM | #5 |
I haven't forgotten about ya just haven't gotten ahold of my buddy yet. This ice storm has screwed everything up.
01-15-2007, 09:43 PM | #6 |
Sierra Grande Club
On my vr4 Galant I had a guy do a custom chip, (Keydiverchips.com) and he put a phantom knock code, which basically ignored the knock signal. However I also had a led that told me how much knock was occurring.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. |
01-17-2007, 12:03 AM | #7 |
OK my buddy said he has never had a problem with pinging running timing gears on a FI motor. He did say to make sure and run the gear drive straight up at 0 degrees. Hope this helps.
