Old 01-13-2007, 07:13 PM   #1
blazedwelder
blazedwelder's Avatar
Cool inline 6 intake/carburetor question
would i be able to pull the intake manifold and 2 barrel carb off of a 79' integrated head 6 cyl. and bolt it onto my 66' 250 6 cyl.
blazedwelder is offline   Reply With Quote
Old 01-13-2007, 07:19 PM   #2
04Xrider
Registered thread killer
04Xrider's Avatar
Re: inline 6 intake/carburetor question
The intake is part of the head on those. But if you are talking about bolting the integrated head on your engine, you can. The exhaust will be different.
04Xrider is offline   Reply With Quote
Old 01-13-2007, 11:03 PM   #3
ol Curt
Junior Member
ol Curt's Avatar
Blazed,
Why not just buy a 2 barrel carb? Or is the issue need of an intake?
ol Curt is offline   Reply With Quote
Old 01-13-2007, 11:12 PM   #4
blazedwelder
i only have a single barrel carb/intake right now.. is there any benefit to having the integrated head?
Old 01-13-2007, 11:33 PM   #5
ol Curt
Junior Member
ol Curt's Avatar
I would say no advantage at all to go to an integral head.
You can get a 1BBl to 2BBl adaptor for $15 and still use your stock intake.
Then use a 2bbl Holley Weber and you'll be set!
Old 01-13-2007, 11:37 PM   #6
04Xrider
04Xrider's Avatar
Those heads are also prone to cracking. I would get a adapter or after market intake before I would put one of those heads on.
Old 01-13-2007, 11:43 PM   #7
Fred T
Cantankerous Geezer
Fred T's Avatar
The integral head was not one of the general's better ideas. In addition to cracking, the air flow is terrible. You can swap heads to use the integral head, but in the long run I don't think you will be happy with it.
Fred
There is no such thing as too much cam...just not enough engine.
Fred T is offline   Reply With Quote
Old 01-14-2007, 12:38 AM   #8
blazedwelder
where can i find a 1 - 2 barrel adapter?
Old 01-14-2007, 12:53 AM   #9
ol Curt
Junior Member
ol Curt's Avatar
Here you go. Great buys on the carbs too. If you want to add a little punch to a six, he's the guy to talk to.
http://www.stoveboltengineco.com/aca...p?productid=91
Old 01-14-2007, 01:37 AM   #10
stsalvage
Scrapper 1
stsalvage's Avatar
well i got a better one for you offandhouser makes a 4bb intake that will give you better gas milage and a lot more Horse power and there alum and never heard them checking 3-5 diffrent companys use them they even make a tri power with 3 carbs 3 2bb carbs that will get you up to 900 cfm's when you open full throtal
stsalvage is offline   Reply With Quote
Old 01-14-2007, 01:41 AM   #11
stsalvage
Scrapper 1
stsalvage's Avatar
well i got a better one for you offandhouser makes a 4bb intake that will give you better gas milage and a lot more Horse power and there alum and never heard them checking 3-5 diffrent companys make them They even make a tri power with 3 carbs 3 2bb carbs that will get you up to 900 cfm's when you at full throtal and that is what i'm doing to my 292 with a700R4 i think in 1979 they went to a 292 with a 4bb carb with a th400 trans in the shortbed fleet side and step side
Old 01-14-2007, 01:51 AM   #12
ol Curt
Junior Member
ol Curt's Avatar
I had an Offy intake with two single barrels, and one with a 390 cfm Holley. Trust me, neither had the drivability or gas mileage of the progressive Holley Weber 2bbl.Name:  Truck Pics 002.jpg
Name:  Progress Holley_Offey 1_05 018.jpg
Old 01-14-2007, 09:55 AM   #13
Fred T
Cantankerous Geezer
Fred T's Avatar
Call up Tom Langdon at www.stoveboltengineco.com . He can give you an education on the subject. He should be able to set you up with everything you need to run the Holley-Weber carb, and at a decent price. Dual Holley-Weber's is a nice setup, but the manifolds aren't cheap.
Fred
Old 01-14-2007, 10:52 AM   #14
RANDY COX
RANDY COX's Avatar
Not to hi-jack thread but thanks ol-curt for posting that set-up with the holley 4-barrel I just recieved my offy 4 barrel intake next thing will be carb,so sounds like the holley is not a good carb for this application.do you have pixs of the holley-weber carb setup.Thanks Randy
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-14-2007, 12:55 PM   #15
blazedwelder
thank you very much everyone i really appreciate it
Old 01-14-2007, 01:17 PM   #16
ol Curt
Junior Member
ol Curt's Avatar
Whether or not it is a good setup is personal preference. I was looking for reliability an better gas mileage. The 2 bbl gave me that.
I should say after i got past the hotrodding stage I decided to build the truck back close to how it was when my grandpa (Curt) bought it. Hence, the motor you see at left with a 1bbl Rochester!
Old 01-14-2007, 02:48 PM   #17
RANDY COX
RANDY COX's Avatar
Ol-curt what are the specs on your engine I see 4 barrel intake also headers did you do anything internally like bigger cam or is everything stock,how did it run with the intake-carb and headers,was it worth it.Sounds like the two barrel did better.
1964 BBC 402 4x4
Old 01-14-2007, 10:22 PM   #18
blazedwelder
will the 2bbl carb off of the integral head 6cyl work with that adapter?
Old 01-14-2007, 10:27 PM   #19
ol Curt
Junior Member
ol Curt's Avatar
I think so. Any 2 bbl should work.
