Old 01-13-2007, 09:03 PM   #1
71sub
71sub's Avatar
Lost keys -- how to remove ignition cylinder
I purchased a complete lock set for the door and ignition -- BUT how do I remove the ignition cylinder w/o the original key ? I know of the small pin hole BUT can't twist the cylinder since I don't have the original key.
Any ideas !!! Haven't used the truck in months -- I'm "jonson" to drive it.
Ev
71 C/10 : 350 / 700r4 ; Ford 9" posi 3.50 with 31x10.5 rear tires, single drive shaft, C-notch, 2.5" drop spindles, keyless entry
71 Suburban 350/350 -- caddy tail lights, keyless entry, late model seats, billet Autometer instrument cluster
70 Ford Torino -- 351W (balanced & blueprinted ), C4, VDO gauges
71sub is offline   Reply With Quote
Old 01-13-2007, 09:46 PM   #2
short69
short69's Avatar
Re: Lost keys -- how to remove ignition cylinder
well, i'm sure theres a more logical way of doing it but the only thing that I can think of is to drill the SOB out!
69 shorty w/ 67 front clip
short69 is offline   Reply With Quote
Old 01-13-2007, 11:13 PM   #3
409biscayne
409biscayne's Avatar
I just had the same problem with my 72 , but i went a different way , a locksmith years ago told me you can pull the pass. side door lock , and have a copy made from it , it has the code stamped on it , this presumes that the ign switch is the original . It worked for me a couple of weeks ago . Oh yeah , you'll need to go to a real locksmith not the kid at Lowe's , etc.
Good luck ................................................. Doug
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 01-13-2007, 11:38 PM   #4
71sub
71sub's Avatar
OK, I had different keys for door and ignition but I didn't know about the code being stamped on the passenger side door lock !!
So, I guess I'm going to need to drill the old one out -- anyone ever do this, any tips / tricks / suggestions ?
Thanks for the help !!!!!
Old 01-14-2007, 12:00 AM   #5
GMCMAX
Active Member
GMCMAX's Avatar
Have you checked out some of the stuff from member LockDoc?
http://67-72chevytrucks.com/vboard/s...d.php?t=213860
http://showcase.netins.net/web/backt...formation.html
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 01-14-2007, 12:39 AM   #6
71sub
71sub's Avatar
That answers THAT !!!!!!!! Thank y'all for this information ...
Ev
Old 01-14-2007, 01:07 AM   #7
brak
brak's Avatar
personally i would just go to the parts store, and buy a new ignition switch.
The time and effort it would take to remove the old cylinder is definatley worth the $13 it would cost for a new switch.
2003 GMC Sierra 1500 WT
1995 Nissan Hardbody
2016 Hyundai Veloster Turbo
DC2 (SW/AW) Clyde W. Harvey USN
"Socialism is a philosophy of failure, the creed of ignorance, and the gospel of envy, its inherent virtue is the equal sharing of misery" Winston Churchill
brak is offline   Reply With Quote
Old 01-14-2007, 01:24 AM   #8
sjarrett71
sjarrett71's Avatar
I just changed mine last week and had to drill (chisel) the old one out. Bought a new switch, cylinder and keys, and bezel. Good as new!!
-Scott-
sjarrett71 is offline   Reply With Quote
