Adam B
Tighten Tilt Column?
Ok, I am installing a 72 Blazer Tilt column in my '68 C-10 truck. The tilt part of the column is very tight and works great. The tilt action is very firm, but the steering wheel is not firm and gives me 1/8 inch of movement in any direction.
I have just installed new steering u-joints and everything on this part is firm and in place. So I don't think it is this far down? Is there a part of the column that needs tighten up or something? A bearing replaced or bolts tighten up?? Any help would be appreciated. Adam |
its all about the +6 inches
Re: Tighten Tilt Column?
from your description, you need some front end work
member #16
![]() Join Date: Dec 1999
The tilt columns have tapered bearings at the top. I dont remember the size but it takes a deep socket. That will usually get rid of the slack. Might not hurt to see if there is any lube left.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ Last edited by john; 01-14-2007 at 06:23 PM. |
