Old 01-14-2007, 01:20 AM   #1
stsalvage
Scrapper 1
stsalvage's Avatar
1967-1970 trucks that had the 396-400
any one know the name of the part that was the thing that kick down the trans only modal that was used was on the big block trucks with the 400 trans and what dose it really do? sorry all 1967--1972 i ment to say
Last edited by stsalvage; 01-14-2007 at 01:21 AM. Reason: wrong wording on the header sorry all
stsalvage is offline   Reply With Quote
Old 01-14-2007, 01:25 AM   #2
Aarons72s
Re: 1967-1970 trucks that had the 396-400
The electric kick down switch? Someone asked about this a little around a month ago. Hard to find and expensive. I couldnt find the thread but know there was one here. Sorry I couldnt find it. The only thing I found that might help is below.
http://67-72chevytrucks.com/vboard/s...ht=kick+switch
Aarons72s is offline   Reply With Quote
Old 01-14-2007, 06:55 AM   #3
JimKshortstep4x4
The kick down switch sends power to the transmissions detent switch which will down shift the transmission depending on the speed of the vehicle. The trucks had two different styles of kickdown switches. Up through 70 the kickdown switch was mounted on the carburetor. In 1971 the kickdown switch was moved inside the cab.
The first picture is the 1970 style of a kickdown switch and the second picture is the 71-72 style of a kickdown switch.
Jim
