Old 01-14-2007, 11:57 AM   #1
Texasdeere
Texasdeere's Avatar
New Rallys won't fit?
I have a 72 C10. I just bought 4 1984 15x8 chevy truck rally wheels to put on my 72 truck. I have over $500 in these wheels, purchase, shipping, and powder coat and the wheels won't fit over the hubs front or rear. Do I need to grind off the powder coat from the center of the wheel to make them fit?
Texasdeere is offline   Reply With Quote
Old 01-14-2007, 12:03 PM   #2
kbs71
71 rustless in texas
kbs71's Avatar
Re: New Rallys won't fit?
Try this thred. http://67-72chevytrucks.com/vboard/s...ls+backspacing there are several diffrent year/stype ralley wheels. Those for all drum and those for disc / drums. You probabaly have the wrong set for your truck.
Hope this helps, it's all I could find in the search. I know there's more info out there,hopefully anoth member will chime in.
"The secret to creativity is knowing how to hide your sources."
"No one really listens to anyone else, and if you try it for a while you'll see why"
71 C-10 LWB presently in a perpetual state of disassembly
'96 Toyota (my work car)
'04 Mustang Convertable (wife's car & other money pit)
Latest aquesition and why my trucks still in the garage covered with junk..
2010 Aqua Blue metallic 6 speed Manual LS3 2SS/RS Camaro (I want one of these in my truck
FAQ here
VENDORS here
SUPPORT THE BOARD here
My second favorite SITE
kbs71 is offline   Reply With Quote
Old 01-14-2007, 12:22 PM   #3
cdowns
cdowns's Avatar
i'd suggest first measuring the hub diam and your hole diameter with a caliper or compass to see exactly how much additional clearance is needed//if its just the thickness of the powder i'd just sand it down for a snug fit
Old 01-14-2007, 12:27 PM   #4
SCOTI
SCOTI's Avatar
Clean up the hub & remove any excess coating if there's some there.
If they are 5x5 'truck' ralleys & not 5x4.75 'car' ralleys, they should fit. Is it possible they're aftermarket w/a diff bolt pattern?
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 01-14-2007, 01:33 PM   #5
Texasdeere
Texasdeere's Avatar
I took a dremel tool with a sanding tube and ground off all the powder coat on the inside hub flange of one wheel. I test fit it on the front and back and it fits good now. I am just suprised what a close tollerance fit that is. It is snug but a perfect fit metal to metal.
Thanks for your help, I was starting to panic a little.
Old 01-14-2007, 01:41 PM   #6
too much stuff
Roadtrip!
too much stuff's Avatar
I ran into the same thing. Had to sand the inside of the hub opening to get it to fit on the rear. Another thing i found out was to put a little grease around the axle where the wheel fits snug. This makes it much easier to take off later on. Eric
67 gmc custom lwb dakota truck. Sold...And bought back
69 swb 4x4 project (in progress)
70 c-10 lwb texas truck
70 4x4/BB/bkts/posi/tach(retired)
70 swb (wifes)
70 jimmy camper
71 K-5 factory 2wd
71 cheyenne 4x4/tach/posi/ plow rig
71 Cheyenne20 BB, buckets, tach, tilt, 4 speed
72 jimmy CST wyoming rig
72 jimmy Colorado rig
72 lifted texas 4x4 3/4 ton burb
65 fury conv. 383/auto
65 chrysler 300 "L" 413 auto
too much stuff is offline   Reply With Quote
Old 01-14-2007, 02:30 PM   #7
409biscayne
409biscayne's Avatar
Does anyone have a link to Ralley wheel id's , for the code stamped next to the valve stem vs what car / truck ?
Not trying to hi jack .
Tks ................................. 409
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 01-14-2007, 06:04 PM   #8
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
instead of grease on the hub, try anti-seize compound.
