01-14-2007, 12:37 PM | #1 |
Sound control
Has anyone compared or contrasted dynomat vs the stuff this guy uses?
http://alanhorvath.com/54chevy/doors_quiet.php
Glenn Cumming, Ga (68 C/10 Fleetside LWB 307 (64 C/10 Fleetside Shorty Custom 350, with 73 donor parts aplenty) (2001 Porsche Boxster S - 168 MPH of fun) (2005 Chevy Avalanche Z71 1500) |
01-14-2007, 12:42 PM | #2 |
Keep On Keepin' On
Re: Sound control
Seems a lot more cost effective than Dynomat..
01-14-2007, 01:53 PM | #3 |
Re: Sound control
Depending on what you want to do with it. Check out http://www.sounddeadenershowdown.com for a good comparison of different products and the pros/cons of roof material vs. products like Dynamat. Stuff like that will "work", but you get what you paid for.
01-14-2007, 06:02 PM | #4 |
Adam B
Re: Sound control
I have used and installed this same stuff on my truck. I can't compare to using dyno mat, but it seemed like it quitted things down a bit. The stuff is pretty cheap too, I would definatelly recommend it for the doors, I could notice a hugh improvement on this part.
I have also installed it on the floorboards. If you are wanting to do the stuff on a budget, this is the way to go. Also, if you are installing it on a cold day, get a heat gun or hair dryer to heat up the rubber backing of the stuff. It is pretty sticky stuff, but once you get the rubber coating heated up, it strengthens up the stickness of the stuff. Adam I bought my at Lowes for $10 a roll I think, it is located in the roofing repair section. |
01-14-2007, 06:05 PM | #5 |
Re: Sound control
jimydean you beat me to it. sounddeadenershowdown is very good. definitel ymakes you think twice about the asphault based types!
-1947 3100 -1968 C10 -1970 K20 |
