Door locks
Hello everyone,
I now own a beautiful 1970 swb c-10. The damn doors will not lock with the key. What is the fix for this? All the door parts and pieces car in place, but they do not want to work together...I tried search function, but came up short. Any help would be great. I will post pics as soon as I can David |
Firefighter
It's possible that your key is not the right one for the door locks, or the mechinism is rusted up and will not move..
'72 Chevy SWB 350 Auto '67 GMC LWB 350 4 speed '70 Chevy 4x4 Stepside 350 Auto Yellville, Ar. USA ![]() ![]() |
Re: Door locks
Do they work with the doors open? If they do then the striker adjustment is too tight. Chris
#4 | |
member #16
![]() Join Date: Dec 1999
Re: Door locks
If they lock with the door open adjust as chris said , and if that doesn' t work try pushing in on the door while locking. Sometimes there is enough wear where the cure is a new latch.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors ![]() http://www.flickr.com/photos/1745471...7602865984234/ |
Re: Door locks
a little lubrication can go along way to solving some problems
![]() Join Date: Apr 2004
Re: Door locks
Replace the locks if you need to. They are real cheap and very easy to replace.
'72 2wd blazer, bagged w/ watts link & EDC '72 C10 "Lowered Farm Truck" STOLEN 5-18-11 '66 impala ht |
Re: Door locks
Thanks everybody. I took everything off the door except the door handle and the door panel, now everything works
Re: Door locks
I have the same problem. Door locks while open but not with the key. Do I need to lube/loosen the latch or striker adjustment as descibed above? The next question would be how do you do this?
