283 0r 350?
how do i tell if i have a 283 or 350? i have 350 plugs.
Re: 283 0r 350?
Get the #'s off the back of the block, and look up Mortec.com.
Junior Member
Re: 283 0r 350?
If it is original, it is a 283. The 327 didn't come out in trucks till '66, and I believe the 350 in late 70's. Don't quote me on the 350 part.
I would think the 283 looks a lot different than the 350 in many ways. I'll see what kind of visuals I can find. This might help a little http://www.mortec.com/location.htm Last edited by ol Curt; 01-14-2007 at 10:26 PM. |
#4 | |
65 - Chevy C10
Re: 283 0r 350?
Some visual differences might be on the 283 you will have the oil breather on the intake manifold vs. on the 350 it will be on the valve cover. I may be wrong?? |
Its a Truck Thing......
Re: 283 0r 350?
If it has the original heads than the 283 has 13/16 plugs and has no holes drilled in the heads for the accessories. The blocks look the same except the bore is smaller. 67 was the last year for the 283 in chevys. I have one from a 67 impala in mine. Also the 283 had the breather cannister bolted to the valley under the intake manifold.
Smitty
71 C10 283/3SPD Full Resto 71 GMC 1500 Sierra Grande http://67-72chevytrucks.com/vboard/s...d.php?t=518599 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me home 71 C20 Longhorn/Ole Yellor 69 C30 Former Motor Home, Flat Bed time Last edited by 71meangreenc10; 01-16-2007 at 09:07 PM. |
Re: 283 0r 350?
a 283 will have a hole two hole's in the back of the block one for the distributor, and one for the old breather tube.
65 c10 tore apart 70 c10 305/350th |
Scrapper 1
Re: 283 0r 350?
All 350 engines on the back of the block where the transmission bolts to it the first 3 numbers# should be 397010 never seen a 350 with a diffrent number unless you get to the once peace seal and they say 5.7 remmber 5.0 is a 305
