Old 08-24-2002, 01:49 PM   #1
JHickson6
I Love This Stuff!
JHickson6's Avatar
Does Anyone Have Pics of a Frame with a C-Notch
I want to get an idea on what I have to do to lay the frame on my truck. But more specifically how big the C-Notch has to be and what it looks like welded on the frame. Oh yah, measurements would be greatly appreciated!
Thanks Again
Jared
My Rides
1967 C10 In Pieces for now
1985 Ford B700 SourPuss Bus - BIG BLUE
2003 Silverado CITY WORKER YELLOW!!
JHickson6 is offline   Reply With Quote
Old 08-24-2002, 02:29 PM   #2
justin
PROJECT LO-LYF
justin's Avatar
I saw an add in a magazine that sold bolt in c-notch kits for these trucks. The only problem is that I don't remember which mag. I will try to hunt it down for you.
FOUNDING MEMBER OF THE "O-SH*T, THAT TRUCK IS LOW" CLUB
PROJECT: LO-LYF
Bagged 68 Shorty
home.att.net/~justin.lewis
justin is offline   Reply With Quote
Old 08-24-2002, 03:00 PM   #3
Slammed67
Progress = 0%
Slammed67's Avatar
Here is the one that I think Justin is talking about. It's made by Classis Performance Products. Nice product although I had to redrill a few holes that didn't line up like they were supposed to. Also, if you use the Early Classic modified track bar kit, you will have an interference problem as shown circled in red in the second picture.
CPP C-Notch
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Old 08-24-2002, 03:47 PM   #4
nosto
Flamin' Bass
nosto's Avatar
Back when I was just beginning with the C-10, I ordered the full AirLift kit (front and rear). Very pricy!! If I knew then what I know now...I probabily would have done what a lot of board members have done - buy the parts and make your own.
Anyhow here's what the cut line looked like before I hacked the frame:
Rick Olson /nosto/
Galloway, NJ
Pics : http://community.webshots.com/user/nosto53
1972 Triumph TR6 - full resto, now with a Toyota 5-speed
1975 F**D F-100 - rusty, but reliable
1982 HD XLH-1000
1967 C-10, shortstep, 350/M21 4spd, nitrogen tank fills fast bags on 4 corners, Toyo 255/45X20s on American Eagle 221 20X8s, shaved locks and handles, antenna, fuel filler, tiny C-notch, rear fuel tank, long headers, Edelbrock, worn 600 Holley, Checkmate flush hard cover, rear pan, custom LED taillights - painted it, too! But don't like it so I'm gonna do it again!!
nosto is offline   Reply With Quote
Old 08-24-2002, 03:50 PM   #5
nosto
Flamin' Bass
nosto's Avatar
And here's the C-notch piece installed.
BTW: The airbag sits 'outboard' of the trailing arm, according to AirLift, to get more drop. I don't know about that, but it sure does make it hard to put wide tires on the rear!!
Rick Olson /nosto/
Galloway, NJ
1982 HD XLH-1000
Old 08-24-2002, 03:53 PM   #6
nosto
Flamin' Bass
nosto's Avatar
Oops! This is the pic that shows the bag mount....
Rick Olson /nosto/
Galloway, NJ
1982 HD XLH-1000
Old 08-24-2002, 03:56 PM   #7
The Blue Pig
Thread Wizard Since 2002
Me and my buddy put a 10' step notch in his frame of his 90 half-ton. The mod would be about the same. He wanted 10 inches so he could lay frame with 20's, but if you are running regular diameter wheels, you shoudl be able to do with 4-7 inches I would guess. We also went ahead and made a 4 link suspension and threw on an MIC air bag suspension, made all the mounts and brackets ourselves though. There is no way you will be able to lay frame with just a "C" notch, you will need to step notch the frame (I think this also may be referred to as "super C" notching). A C notch cuts into the frame (supposedly) no more than half the frames hieght to maintain structural integrity, while giving a clearance of 2-3 inches above the axle housings of your rear end at ride height, while a step notch actually is a reconstruction (or bolt in if you dont like to fabricate) of that whole section of your frame (normally boxed). We just drew up a template of the side view of the notch (a 10 inch notch is huge) and busted out the old plasma cutter, blasted them out of a piece of flat stock, welded them to the frame (after many cross braces were welded into place from frame rail to frame rail to keep it from losing any measurements) then boxed them in from the top and bottom. Sure, its a lot of cutting, grinding, sticking, welding, and metal finish to make it look descent, but, then you can say you make the damn thing yourself instead of "bolting one on".
--70 C-10 Longbed
--71 C-10 Longbed
--72 K-20 Longbed
--74 C-10 Shortbed
--86 Toyota Tercel (His Driver)
--05 Chevy Trailblazer (Her Driver)
The Blue Pig is offline   Reply With Quote
Old 08-24-2002, 04:08 PM   #8
justin
PROJECT LO-LYF
justin's Avatar
yea Slammed67, I have the same problem with my adjustable pan hard bar. We fabricated my c notch, I was trying to find a pic of it but I'm not having any luck.
PROJECT: LO-LYF
Bagged 68 Shorty
Old 08-24-2002, 04:49 PM   #9
Church
Carolina Classic Trucks
Church's Avatar
here's the one I did, shown with ECE air bags. No need to buy a kit, just take a piece of pipe the width of the frame and cut it in half. box your frame then take a plasma cutter and cut out the "c" notch, then weld pipe in. It really is a piece of cake if you have the right tools.
Church is offline   Reply With Quote
Old 08-24-2002, 05:06 PM   #10
Church
Church's Avatar
this one shows air bag, sorry
Old 08-24-2002, 07:55 PM   #11
Slammed67
Progress = 0%
Slammed67's Avatar
nosto: I also looked at Air Lift and Air Ride Tech's kits, but figured I could do the same thing for a lot less money. I don't see how it can go lower mounting the bags outboard, because the bottom of the bracket looks like it is at the same height as the bottom of the frame.
Justin: to fix the problem, I hacked up the ECE bracket and welded the "clevis" part to the inside of the trailing arm.
Old 08-25-2002, 04:48 PM   #12
JHickson6
I Love This Stuff!
JHickson6's Avatar
Thanks guys for all your help, you never disappoint me!!
Jared
My Rides
Old 08-25-2002, 06:46 PM   #13
justin
PROJECT LO-LYF
justin's Avatar
hey slammed67
Do you have a pic of what you did? I am not quite following you. What is the "clevis". I know what the clitoris is but not the clevis. Thanks
PROJECT: LO-LYF
Bagged 68 Shorty
Old 08-25-2002, 06:55 PM   #14
Slammed67
Progress = 0%
Slammed67's Avatar
Talking
Sorry, I guess "clevis" was a poor choice of works. It's the thing that the end of rod slides into (Where the track bar mounts to the bracket).
Here's a pic:
Old 08-25-2002, 07:02 PM   #15
justin
PROJECT LO-LYF
justin's Avatar
So you basically lowered where the bar attaches to the bracket?
In other words you stuck the rod in the lower hole
PROJECT: LO-LYF
Bagged 68 Shorty
Old 08-25-2002, 07:08 PM   #16
Slammed67
Progress = 0%
Slammed67's Avatar
well, actually I cut that part of the bracket off and welded it to the inside of the trailng arm.
Old 08-25-2002, 07:20 PM   #17
justin
PROJECT LO-LYF
justin's Avatar
O!!
I got you now. I am going to have to try that! How does that truck ride with the bags?
I cant wait to fire mine up!!!
PROJECT: LO-LYF
Bagged 68 Shorty
Old 08-25-2002, 10:41 PM   #18
Kid
Kid's Avatar
Question for SLAMMED 67, what is the part # of the bags in your picture? Are they part of the Early Classic kit?
Kid is offline   Reply With Quote
Old 08-25-2002, 11:34 PM   #19
Slammed67
Progress = 0%
Slammed67's Avatar
Kid,
the rear bags are 2500lb Firestones, the fronts are 2600lb. I didn't get them from ECE...... I'm not sure what they use in their kits.
By the way, where abouts are you in Kansas?
SLAM
Old 08-26-2002, 12:52 AM   #20
JHickson6
I Love This Stuff!
JHickson6's Avatar
Hey Slammed67, now that you've got the wheels on the truck, and most of the weight when the bags are empty how much clearance is their on the side of the frame? Say at about where the cab is. Do your rockers hit the ground, does the frame hit the ground?
Thanks Again
Jared
My Rides
Old 08-26-2002, 09:18 AM   #21
Church
Church's Avatar
Hey Kid, Mine are from ECE and they are firestone bags.
I have a pic in an earlier post.
Old 08-26-2002, 01:47 PM   #22
Slammed67
Progress = 0%
Slammed67's Avatar
JHickson6: No, neither the frame nor the rockers hit the ground. However, the front crossmember is about 1" off the ground. I can get some frame-to-ground measurements if you are interested.
Old 08-26-2002, 02:04 PM   #23
JHickson6
I Love This Stuff!
JHickson6's Avatar
That would be greatly appreciated as I like the ride height of your truck, and I might just go with the same setup as you instead of laying the frame.
Jared Hickson
My Rides
Old 08-26-2002, 03:00 PM   #24
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
These trucks will never lay frame with a tire taller than 27", UNLESS you notch the front crossmember and a huge notch in back probably 8" or more.
This is a pic of my old 72 GMC front crossmember sits about like slammed 67's, the rear I stepped 6". The front frame about 1.5" and the rear about 1.75"
01 Tahoe 22's 2/4 drop and tv's
68 chevy money pit
51 chevy belair
95 Honda 900RR
05 GMC Siearra (company truck)
NSANE68!!! is offline   Reply With Quote
Old 08-26-2002, 03:02 PM   #25
NSANE68!!!
SLICER AND DICIER
NSANE68!!!'s Avatar
Wink
Here is a pic of the finished product. But be warned this is alot of work all hand FABBED, not for the average person.
68 chevy money pit
51 chevy belair
95 Honda 900RR
