Old 01-15-2007, 12:43 AM   #1
CentralCoaster
CentralCoaster's Avatar
Question Antenna wire routing?
I'm trying to install a new antenna, but can't figure out how to get the wire to the stereo. It had none when I bought it, but the hole is there. It just opens up to the cowl area where the heater air draws from.
It's an 69 bare bones Air Force truck, but I assume it came with an antenna originally.
1969 C10 Stepside, 350ci, 700R4
CentralCoaster is offline   Reply With Quote
Old 01-15-2007, 03:55 AM   #2
Brad
Out of the carpool lane.
Brad's Avatar
Re: Antenna wire routing?
There should be a hole just underneath the cowl. You'll need to take that off and you'll see it on the passenger side.
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 01-15-2007, 12:31 PM   #3
CPNE
Resident Curmudgeon
CPNE's Avatar
The stock hole for the antenna lead is shown in this pic. It is the hole below the windshield opening by the front cab pillar. It is hidden by the cowl when installed.
Currently on or near the homestead:
67 Chevy SWB 2WD stepside 350/3 on tree (Pat's)
67 GMC SWB 2WD Fleet 402/auto (Brian's under construction)
67 Chevy 3/4 ton 2WD 402/auto (Business Hauler)
67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC)
68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC)
70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC)
71 Chevy SWB stepside (Crushed by tree - parts donor)
72 Chevy 3/4 ton 4WD (Parts donor)
72 Chevy 3/4 ton 4WD Suburban (Parts Donor)
72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC)
81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler)
82 Camaro Z/28 355/Super T-10 (Pat's toy)
93 Caprice 9C1 (Brian's Cop Car)
02 Toyota Camry (Reliable but a souless steel and plastic hulk)
2011 2SS RS Camaro M6 Factory Hurst Shifter
Maybe I need to sell some of this crap
Yet another Bozo with a sawz-all
CPNE is offline   Reply With Quote
Old 01-18-2007, 02:26 AM   #4
CentralCoaster
Thanks for the pic...
I pulled the glovebox, and see a flat spot in that location that is not drilled.
The rpo list has a "radio delete" option, so that explains that.
I found some type of hidden antenna glued to the back of the cardboard glovebox. So I gues I can put the real antenna in there or just fill the hole in the cowl.
