Old 01-15-2007, 02:33 PM   #1
mhicks
mhicks's Avatar
Stepside Tailight Question
I purchased some 1973 stepside tail lights from LMC for my truck. The connector on the light has the same sex connector as the connector on the truck. My son has a 74 and the connector on the light is the same sex also. Does anyone know where I could get the correct lights with the correct connector? Or maybe purchase the correct connector and install it on the light. The light needs to have the 2 female spade lugs instead of male. I also purchased a couple of backup light and they needed to be a single female and they came with a round male plug. Do any of you know where to get the correct lights with the correct connector?
Mike
mhicks is offline   Reply With Quote
Old 01-15-2007, 07:47 PM   #2
mcssls
Re: Stepside Tailight Question
cut the connectors off and splice the right one on.
mcssls is offline   Reply With Quote
Old 01-15-2007, 08:28 PM   #3
stepside454
stepside454's Avatar
yep...or I bought mine at my local carquest.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
Old 01-15-2007, 09:05 PM   #4
mcssls
got mine at autozone, had to rewire it all anyway, all the back half wiring was rotten.
Old 01-16-2007, 12:21 AM   #5
stepside454
mine from Carquest plugged right in to factory connector. John
Old 01-16-2007, 03:33 AM   #6
Bad71chev406sbc
Bad71chev406sbc's Avatar
Just upgrade to LED units....that's what I did. Don't you love it when parts aren't the way they should be??? Just hit up the autoparts store....or the junk yard to get the right plugs and splice into your wiring harness.
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
Bad71chev406sbc is offline   Reply With Quote
Old 01-16-2007, 06:54 AM   #7
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: Stepside Tailight Question
Call LMC and tell them what you have and ask then to verify if they have the correct part for your truck and send them the wrong ones back.
If not do what stepside 454 said and send the bad ones back to LMC.
mcssls, I think that he wants to keep the stock look and function of the original design of the tail light assembly.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-16-2007, 10:37 AM   #8
mhicks
mhicks's Avatar
I sent them back to LMC and talked to them and they didn't seem to know they were wrong. I really didn't want to splice them if I didn't have to. I have talked to several other aftermarket vendors and they all had the wrong plugs on them. I will check the carquest website and see what they have. Thanks for the help. I have been looking at the truck stops at the round LED tail lights and have been thinking about trying to make the guts out of one work. Still just a thought right now though. I talked to several Chevrolet dealers in the area and they discontinued them about 10 years ago. The only part you can get from them is the lens for the backup light.
Old 01-16-2007, 11:29 AM   #9
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Are you looking for new lights or the connectors? I have some from my '74 that I am selling:
http://p210.ezboard.com/f7387chevytr...picID=17.topic
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 01-16-2007, 02:02 PM   #10
mhicks
mhicks's Avatar
I was looking for new but will take used. PM sent. I am still needing a good driver's side tail light.
Thanks.
Old 01-22-2007, 08:03 AM   #11
Bad71chev406sbc
Here's some pics of what mine look like. I made brackets that bolt into the stock holes....as well and one hole from the reverse light bracket. I'm not running the reverse lights....I think they look too cluttered. I used cheap $13 ones from a tow truck supply. The brand is Maxxima. Pics:
