advantage of useing 73-87 front member ?
i have a 70 c-10 and was thinking of going to the 73-87 front x member to get the disc brakes and power steering. i see they have rubber control arm bushings instead of the metal ones i have now. does that give it a better ride? are there any other differances that are better than the 70 ?
70 c10 stepside ,350v8, m-20 4 speed ![]() |
![]() Join Date: Jun 2002
Re: advantage of useing 73-87 front member ?
First of all is availability. The 73-87 can be found everywhere.
Second of all, you can buy drop spindles and drop coils for the 73-87 cheaper than the 71-72. Only downside is you will have to work on the mounting holes a bit. Good luck, Rg
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
is the ride the same?
I doubt there is a huge difference in ride. But the parts availability is key. The pure number of truck made from 67-72 vs. 73-87 (even if you go back to 63) is what makes the swap so popular.
i figured it would be an easy way to get the disc brakes and power steering if nothing else. wolud there be any issues in hooking up the power steering ? or does everything just bolt up ?
I pulled the motor and steering box out of a '75 and the box bolted right up. I even mounted the old box in the '75 to make it mobile.
On the '69, I had to notch the bumper bracket to clear the box and I cut a little off the inner fender to clear the hoses, but I don't think you have to do either on a 70. |
Yes, there is a slight difference in the ride. Both of my swb trucks are lowered using basically the same methods yet the newer 74 rides a little nicer. The 74 has the rubber bushings vs. the rubber-lined steel bushings on the 68.
Availability is the main reason. It's much easier to find replacement parts for 73~87 (& typically cheaper too). You don't have to swap the entire crossmember over if you're rebuilding the front end. Just swap over the a-arms, sway bar, & steering related gear.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-15-2007 at 05:13 PM. |
The Older Generation
Here are the holes I had to modify to put the later model front end in my '70... LockDoc
A guy with a truck
Newer 'clamshell' engine mounts too...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
Out of the carpool lane.
I would agree with everything that's been mentioned. Long story short- I hate the old screwstyle control arm shafts and ended up stripping threads on a brand new set. I decided after that to just go with the newer rubber style and haven't looked back!
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red 1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!) 2000 Honda VFR in the faster yellow! 2008 Husqvarna TE-610 1967 C-10 SWB 'Six Appeal'-Gone but not forgotten... |
