Old 01-15-2007, 04:02 PM   #1
abadsvt
abadsvt's Avatar
Full out custom or semi stock dash?
Well i am trying to decide what route i am going to take for the dash. I want my truck to be unique and custom but still clean and somewhat simple. I am completly stuck trying to make up my mind. I was hoping you guys could help me out. I am looking for pics of both setups. Really custom dashes maybe a newer year truck dash incorporated into our trucks and also looking for some really clean semi stock dashes. I like the look of the painted gauge cluster so it doesn't stick out so much. I have a few weeks before i am at the stage were i have to decide but trying to do my homework. Thanks alot.
Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 01-15-2007, 04:07 PM   #2
jimmydean
jimmydean's Avatar
Re: Full out custom or semi stock dash?
I like the stock dash with Auto Meter gauges (white, of course). I think that it gives a custom look while keeping the overall stock feel.
jimmydean is offline   Reply With Quote
Old 01-15-2007, 04:07 PM   #3
powell72
powell72's Avatar
My thinking is you're going all out on the whole truck why stop at the dash?
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 01-15-2007, 04:21 PM   #4
abadsvt
abadsvt's Avatar
That is kind of what i am thinking. Just don't know what to do. I like the look of the mid 50's dash. You know the triangle looking dash. I don't know. I am so confused
(Project truck)
Old 01-15-2007, 04:23 PM   #5
abadsvt
abadsvt's Avatar
I love the autometer gauges. I had some in my 65 chevelle ss. If i keep the stock setup then i will definately go with the autometer.
josh
(Project truck)
Old 01-15-2007, 06:22 PM   #6
b&a72
Active Member
b&a72's Avatar
IMO go custom. That is what I am doing alot of my friends have the stock cluster with the autometer gauges.
b&a72 is offline   Reply With Quote
Old 01-15-2007, 06:40 PM   #7
jimmydean
jimmydean's Avatar
You could do what I would like to do, but don't have the time.
Do a molded carbon fiber cluster with Autometer gauges. There is a company that makes one that is sort of cool, but they want way too much for it. If have ever done fiberglass work, then it's the same concept, only use carbon mesh with fiberglass resin.
<edit> Like this, only cooler. I would use the stock locations and have a little better shape to it.
Old 01-15-2007, 07:39 PM   #8
mac
Active Member
mac's Avatar
IMO Autometer has become completely over used. Have you seen the new Stewart Warner Maximum Performance style gauges ? White, black or silver backlit faces. They have a 6 gauge set with senders for @ $400 and they are brand new on the market.
You can make a flat panel to cover the original bezel, fill the switch holes over, LED the turn signal/ hi beam lites,relay the headlites/wipers and fit it with the gauge set. Paint the panel to match your interior. Ditch the heater, smooth the firewall, cut some 20 ga stock and cover the top dash holes all the way across and to fill the stock radio/ashtray/heater control center to smooth it all. Run a relay touch pad in a console or glovebox to control everything. You could even ditch the key switch for a Honda S2000 starter button or use one on the touchpad if you wanted. Put a new dash pad on it and call it soup. You might need a little wiring expertise too.
mac is offline   Reply With Quote
Old 01-15-2007, 07:41 PM   #9
ghetto_superman
ghetto_superman's Avatar
I would like to see a version of the above molded dash bezel that IMO isnt so hideous.. lol it REALLY isnt something id want. but thats just me.. i dontmean to offent anyone, but whoever designed that must have been thinking Arby's...
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 01-15-2007, 07:43 PM   #10
1969k10stepside
I just prefer the original tach dash
1969k10stepside is offline   Reply With Quote
Old 01-15-2007, 07:49 PM   #11
Southedisto
River life......
Southedisto's Avatar
Here is mine, former glove box door. I cut hte inner part off and hole sawed the holes. I should have put the tach and speedo closer together, but it will work for me.
Southedisto is offline   Reply With Quote
Old 01-15-2007, 07:57 PM   #12
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Here's mine. Not sure it's what you're lookin for but it's purty clean!
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 01-15-2007, 08:16 PM   #13
Hart_Rod
Hart_Rod's Avatar
Here's what I'm using.
Hart_Rod is offline   Reply With Quote
Old 01-15-2007, 08:25 PM   #14
jsbgump
Gone Fishing
jsbgump's Avatar
That set up looks really good hart rod
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started
2022 Hyundai Tucson Limited
2019 Chevy Traverse Redline Edition Wifes Ride
Build Thread
http://67-72chevytrucks.com/vboard/s...=1#post3483616
jsbgump is offline   Reply With Quote
Old 01-15-2007, 08:32 PM   #15
lamar
lamar's Avatar
I think nothing looks better than a nicely restored tach dash. When it is done right nothing looks better.
72 C-10
lamar is offline   Reply With Quote
Old 01-15-2007, 08:32 PM   #16
N2TRUX
Happy to be here
N2TRUX's Avatar
Here's a couple....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-15-2007, 08:41 PM   #17
piecesparts
Parts and more parts
piecesparts's Avatar
I'm working on the idea of using the dash and glove box from "No Limit Engineering", It is the same one that was installed in "Copperhead"---call me crazy, but I liked the look.
piecesparts is offline   Reply With Quote
Old 01-15-2007, 08:43 PM   #18
onetonk5
Cereal Killer
onetonk5's Avatar
my choice is a mint gauge with tach dash......black over chrome!
onetonk5 is offline   Reply With Quote
Old 01-15-2007, 08:44 PM   #19
[ol'Blue]
[ol'Blue]'s Avatar
that suburban is bad ass
[ol'Blue] is offline   Reply With Quote
Old 01-15-2007, 09:13 PM   #20
cstm68
cstm68's Avatar
heres mine i cut 1/8 in aluminum and used a 5" automeater tach 5" speedometer and a 2-3/8" fuel guage. its not done yet, im goint to mill some billet lines into it on the two bottom spots next to where the colum comes out and they will get painted the same color as the truck.
i also used matching guages in my center console.
cstm68 is offline   Reply With Quote
Old 01-15-2007, 09:36 PM   #21
jimmydean
jimmydean's Avatar
I agree. The idea is great, the execution is way off!
I want to do something with the gauges in the stock location, but with some smooth shape. I also like the billet cluster, then use the trans black powdercoat I have over the top.
Old 01-15-2007, 09:49 PM   #22
texascowboy593
texascowboy593's Avatar
How about the dash pad? This is from www.justdashes.com
I also painted the interior of my gauges...Simple process!
"The rays of light thru the Shiner Bock bottle make me wanna turn the key and put down the throttle...and get lost down 35" - Jason Boland
www.YouTube.com/user/593Films - Watch My Videos!
1977 Silverado K10
2014 Dodge Durango (Wife-mobile)
2008 Dodge Ram Lone Star Edition (Daily driver)
texascowboy593 is offline   Reply With Quote
Old 01-15-2007, 10:03 PM   #23
jimmydean
jimmydean's Avatar
How much was that dash pad. I thought it was kinda silly until I had to mount 3 gauges for my air ride. If I went with that, I could mount my air gauges there and it would be slick!
Josh, feel free to steal that idea if you'd like! I think that would be sweet for your air gauges if you don't have a location in mind.
Old 01-15-2007, 10:06 PM   #24
texascowboy593
Hey Jimmy...It was $299 if I remember...They can match whatever color you want if you send them a sample...
1977 Silverado K10
Old 01-15-2007, 10:08 PM   #25
jimmydean
jimmydean's Avatar
Now that I think about it, it won't work because of my video monitor. I think I might do something like that though and flush them into the pad above my current cluster. That way I can see them through the wheel and still have room for my video monitor.
Man, what a pain in the ass.
