Old 01-15-2007, 04:04 PM   #1
C203/4
long or short
th350 Transmission, can you switch out the longshaft on the transmission easily? take a longshaft tranny and add the short shaft to it ?
C203/4 is offline   Reply With Quote
Old 01-15-2007, 04:14 PM   #2
see ten
WTB this ad
see ten's Avatar
Re: long or short
If I'm understanding your question correctly the answer is yes and no. You can change out the short for long (and vice versa) but the shaft runs from the front to the back of the trans causing you to have to disassemble the entire trans for the swap. You can even use a 4x4 trans in a 2wd if you have a 2wd shaft and tailshaft to swap in. So yes it can be done. No it isn't easy unless you build transmissions for a living (in which case you probably wouldn't have asked this question). It might be easier to just swap out the entire trans and have a new driveshaft made or source a bolt in swap.
see ten is offline   Reply With Quote
Old 01-15-2007, 06:16 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: long or short
didn't someone just post the same Q?
Old 01-15-2007, 07:43 PM   #4
ghetto_superman
ghetto_superman's Avatar
Re: long or short
deja vu...
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 01-15-2007, 08:35 PM   #5
Longhorn Man
Re: long or short
Originally Posted by ghetto_superman View Post
deja vu...
Didn't you JUST say that?
Old 01-15-2007, 10:20 PM   #6
ghetto_superman
Re: long or short
lol
