01-15-2007, 06:50 PM | #1 |
FlowTech Headers anyone?
I just gave up and bought a set of these, painted for $105 @ Summit. I usually don't lowball on headers (I paid $1700 for my Impala SS headers!) but I'm in the process of "downgrading" my '72 into much more of a daily driver from my original lofty performance goals. When I build the new chassis I'll spring for a set of tri-y's and a nice system - this is to keep me going for the next 3-4 years.
Anyone installed these? They look about right, and the flange is nice and thick. The tube size is a bit small but that should be fine for what I'm looking for. Looking for personal, direct experience. Thanks! Last edited by Billla; 01-15-2007 at 06:50 PM. |
01-15-2007, 06:59 PM | #2 |
Re: FlowTech Headers anyone?
are they full length or block huggers ??
i used the flowtech full length ones on my 68 and thy fit good i had to remove the oil fiter and the starter to install them! |
01-15-2007, 07:13 PM | #3 |
Active Member
I just took a set of alumi coated Flowtechs off and replaced them with Hedman Ceramic longtubes. I liked 'em fine and had no trouble with the angled plugs on my ZZ4 either. On lowered springs I could drag 'em but they held up fine to a lot of speed bumps and bad angled driveways.
01-15-2007, 07:17 PM | #4 |
The Hammer Man
a little off subject but i have flowtech mufflers, installed 4 years ago and both are now rusted through and i need to replace. just thought i'd share.
Boise69. Bought in Boise ID and its a '69 ___________________________________________ 1969 Chevy C-10 SWB 350/400 - drivable project www.americanhammer.com 2013 MBZ Sprinter customized 2005 MBZ Sprinter Van 2004 Land Rover Discovery 2001 Yamaha Road Star 1997 MBZ E420 1989 Ferrari Mondial T |
01-15-2007, 07:23 PM | #5 |
Full-length. The install instructions say that both of these must be removed...so sounds good so far
01-15-2007, 07:24 PM | #6 |
01-15-2007, 07:50 PM | #7 |
i have a set of these on my 67 and so far so good
01-15-2007, 08:00 PM | #8 |
Gone Fishing
I've had a set on the 68 for almost 9 years. they were ok at first but the collectors warped on me and they look like crap now but hey they work for the price
68 Chevy Short Fleetside LSX Swap Under Way 3.73 posi 2.5/4 drop Frame of resto has been started 2022 Hyundai Tucson Limited 2019 Chevy Traverse Redline Edition Wifes Ride Build Thread http://67-72chevytrucks.com/vboard/s...=1#post3483616 |
01-16-2007, 12:40 AM | #9 |
got them on my 69 swb and i like them
01-16-2007, 12:41 AM | #10 |
I had a set of full length and they lasted 18 months.
RIP to my son Dylan. 5/17/2002 - 8/18/2018 If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started. https://slothforpedcancer.org 68 build thread http://67-72chevytrucks.com/vboard/s...d.php?t=223234 |
01-16-2007, 01:52 AM | #11 |
i got on my '69 and no problems. if your goin in fron the top, take the plugs out, remove the strater, and the brake booster can keep the master cylinder hangin out the lines, and they should drop in. also remove the z-bar and clutch linkage if its manual. only problem i've had with them is gettin the reducer to collector gasket to seal up. used 2 paper gaskets per side and haven't had a problem. chris.
its a work in progess. 71 c-10 lwb, in the middle of frame off restoration. 69 c-10 swb, drag truck, 406 sbc, balanced, comp 292 cam, ported, polished, gasket matched, and bowl blended pro comp 210cc heads, 2.02/1.60 ferrea valves,1.6 roller rockers, re curved hei with msd 6al box, 2-step rev limter, accel 300+ wires, ported victor jr intake, holley 750 double pumper carb, dynomax 1 5/8 headers, 4 spd munci m-20 with super case and iron midplate, mr. gasket vertigate shifter, 5.38 pro gears with full spool, 33 spline moser axles and c-clip elimators, line-loc, 5 gal fuel cell, holley blue pump. 7.807 @ 88.37mph 1.60 60FT 80 g-20 van, tow rig, cammed 305, th350, 10 bolt 88 jeep wrangler, dd, 258, ax-15 swap, 4.5" lift, 33x12.50's, lockers, 3.55's |
01-16-2007, 01:59 AM | #12 |
Oilfield Trash
i have a set on my truck, no problems so far, but i only put about 1000miles on y truck so far. I never had to remove anthing to get the headers in, driver side was a tight fit though. Makes me wonder if my engine mounts are in the right spot.
14 Dodge 3500 Mega Cab 08 Dodge 3500 Mega Cab 87 Chev 3+3 4x4 80 GMC K10 High Sierra bone stock 70 Chevelle 350SS long term project 68 GMC 3ton Grain Truck/Garbage wagon 50 Pontiac 2 Door Coupe Project "I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr. |
01-16-2007, 02:16 AM | #13 | |
i had to replace both motor mounts to get my headers to fit-----rubber in both mounts collapsed |
01-16-2007, 09:57 AM | #14 |
01-16-2007, 10:45 AM | #15 |
yes---rubber collapsed and the motor sat to low and the headers hit crossmember so the bolt holes wouldnt line up-----tha mounts was basicly metal to metal
01-16-2007, 11:06 AM | #16 |
Nothings as cool as my 72
Mine were pretty easy to installing seeing that I didn't have a body on the frame. Haven't fired up the truck yet so don't know how they hold up yet.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. |
01-16-2007, 11:59 AM | #17 |
01-19-2007, 01:47 PM | #18 |
These arrived yesterday and I was underwhelmed. I think I'm going to go ahead and install them...but I was not real happy with the "quality". I know it's a lowball header, but I was surprised at the really poor welds and what looks like flanges that are ground on a bias. I'll post some pictures along with the installation, but out of the box I was not rocked.
Based on what I saw, I wish I had spent the extra $30-$75 on the painted Headman or Hooker Competition headers and that would be my recommendation - and of course the good thing as well is if you upgrade to coated headers they (should) bolt right up. |
01-19-2007, 02:47 PM | #19 |
~Rest In Peace~
i got flowtech on my blower motor and they work real good i also read in hot rod mag that they did a headers test and these flowtechs were rated right up with heddmen and other for the overall performance
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
01-19-2007, 03:17 PM | #20 |
I bought a set of full length flowtechs for my '68 and they worked just fine for the money. I eventually upgraded my entire exhaust system just as you're talking about doing with some hedman elites.
01-19-2007, 05:41 PM | #21 |
sufficiently talented fool
I put them on mine, and the flanges do not have a gasket at all. No leaks, and they fit pretty well. My truck sits in the garage, and we put 500 miles on it this year, so it is not used a lot. I like them and would buy another set. My SS Impala now has a crack in the exhaust manifold, so I am going to join you and shell out big bucks for some LT1 headers.....
"it's impossible to be surrounded by idiots when you are part of the circle" 2003 Suburban 2002 Pontiac Montana 1981 Corvette 1966 Impala Convertible Click here to support the board |
01-20-2007, 12:17 AM | #22 |
had mine for about 4 years now. no problems. lil deeper sound. didnt have to take any tihng off to intsall. i installed from under the truckk(truck jaked up...rite in. i like em. like you say cant beat the price.
02-04-2007, 07:25 PM | #23 |
[UPDATED]FOLLOW-UP
Finally had time today to start the install on these. They have MAJOR interference on the motor mount on the passenger side. I wouldn't mind clearancing a bit...but it would have to be maybe 1/4" and I'm not doing that. Moving to some Hookers, which is what I should have bought in the first place. You can see from the pictures I posted in the thread below the difference between the two headers. I guess the determining factor is how far forward your mounts are. http://67-72chevytrucks.com/vboard/s...13#post2017213 Last edited by Billla; 02-04-2007 at 08:39 PM. |
02-04-2007, 11:26 PM | #24 |
10 year old Hookers. I bought them from the Super Shops for $60 when they were clearing out stock right before the locked their doors for the last time.
Passenger side, hard to tell from the picture but there is at least 2" of clearance to the motor mount. A little further back, Dang autofocus. Driver side, also at least 2" of clearance. Again, further back. Pictures are dark because I took them at night.
Oscar '72 Shortbed Fleetside '95 Jimmy 4X4 '69 GMC Custom Camper Last edited by FLEET72; 02-05-2007 at 05:04 AM. Reason: Fixed pictures, changed to links, hope that works. - Picasa - |
02-05-2007, 01:07 AM | #25 |
Designated A-hole!
Nothing but red x's showing for me fleet72.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
