Old 01-15-2007, 07:55 PM   #1
stllookn
Saving 1 truck at a time!
stllookn's Avatar
Quadrajet Divorced Choke w/Edelbrock
I am trying to mount my Rochester Quadrajet on an Edelbrock intake and noticed that the divorced-choke stove platform is about 1/2-inch further away from the carb than the stock manifold. Is there a special off-set link for this adaptation?
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 01-15-2007, 08:00 PM   #2
Madbomber88
Active Member
Madbomber88's Avatar
Re: Quadrajet Divorced Choke w/Edelbrock
Which Edelbrock intake are you running? I've done the exact same thing and didn't have any problems, but I was running a Performer intake. It might not even matter. The choke coil moves quite a bit and may make up the slack
71 Blazer CST
72 K20
Capt USAF
Madbomber88 is offline   Reply With Quote
Old 01-15-2007, 09:09 PM   #3
stllookn
stllookn's Avatar
Performer intake as well. I was just looking at it and trying to get it all sorted out before gluing it on the motor. It is on my test stand right now so I still have time to work it out. I was wondering if it just came off the other side (inside instead of outside) of the heat stove/spring...that could account for the difference.
Old 01-15-2007, 09:22 PM   #4
rage'nrat638
rage'nrat638's Avatar
heres some pictures you will need to bend your own linkage rod from 5/32 welding rod...
this is a proformer intake manifold..
rage'nrat638 is offline   Reply With Quote
Old 01-15-2007, 11:29 PM   #5
stllookn
stllookn's Avatar
rage'nrat638, That is what I thought...no problem then! I don't want to run the stock intake if I don't have to and I like the Qjets...easy to rebuild and tune. ROCK ON!
Old 01-15-2007, 11:37 PM   #6
jhow66
jhow66's Avatar
Used this kit on a Q-Jet on Edelbrock BB that had the same problem:
http://store.summitracing.com/partde...5&autoview=sku
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 01-16-2007, 02:26 AM   #7
beater69
Sinister Exaggerator
beater69's Avatar
I've just bent them out of the older "heavy" wire hangers. Just don't let you wife see you stealing her hangers. I guess i'm pretty white trash though
69 c10 Chevy Long Fleet 350/350 *under construction*
Poor man's disc brake upgrade with HydroBoost from '82 diesel
Blazer tank with "John Fabris" stake pocket filler (Genius!)
beater69 is offline   Reply With Quote
Old 01-16-2007, 02:52 AM   #8
stllookn
stllookn's Avatar
jhow66, Thanks...good idea...since I might have to order a new stove kit with spring. Mine is bent and may be trashed. beater69...LOL!
