![]() Join Date: Aug 2003
Wiring Harness ?
I'm removing the engine and trans. from a 2000 GMC truck and need to know how to remove each part of the harness from the main fuse panel on the d/s inner fender. I only want to remove the part of the harness I need and leave the rest. Can you remove the bolts in the underside of the main harness,pull the fuses and seperate? Thanks in advance.
