HEI Vacume Advance?
Ok folks, found out that my distributor was 180 degrees off. I fixed that and got the timing perfect. However I wasn't sure what the vacume advance timing should be at. I'm reading it at 40 degrees is that right? Where should it be?
68 327 egine Hei Ignition |
Re: HEI Vacume Advance?
Sounds about right. With the vac line pulled off you should be at about 8* at idle and the vac should give about 32* total advance.
Kevin LFD Inc. |
