Old 01-16-2007, 12:56 AM   #1
skokie
skokie's Avatar
What is this and do I need it?
Circled in blue.
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-16-2007, 01:04 AM   #2
sjarrett71
sjarrett71's Avatar
Re: What is this and do I need it?
That looks like a heat riser and I've never seen one that was in working condition. Most of them were wired open.
-Scott-
sjarrett71 is offline   Reply With Quote
Old 01-16-2007, 01:04 AM   #3
The Hard Way
That's a heat riser. It helps your truck warm up faster. If it's working well and you live in a cold area it might be easier to leave it in, but obviously they're obsolete since vehicles haven't used them in ages.
The Hard Way is offline   Reply With Quote
Old 01-16-2007, 01:05 AM   #4
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
That looks like a heat riser valve (not sure of the correct term). It closes when the vehicle is cold so that warm air is forced up through the riser into the air cleaner and carb. I would say it isn't required but may help your truck run better when it is cold outside. If you aren't running a factory style air cleaner, it probably isn't serving any purpose whatsoever.
I'm not bad with mechanics but you should probably wait for another, more knowledgable board member to confirm.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 01-16-2007, 01:06 AM   #5
skokie
skokie's Avatar
Sounds like I wont be needing it. The exhaust manifolds are coming off to get blasted and painted. It will be heading to the garbage can.
68 build thread
Old 01-16-2007, 01:07 AM   #6
wheels67
wheels67's Avatar
I know somebody will "Pipe" up .......get it, PIPE up.
My uneducated guess is its a vavle to help your truck warm up faster by closing the exhaust tube until temp is reached. You may not need it if you live in a warm area or have no emmision laws.
wheels67 is offline   Reply With Quote
Old 01-16-2007, 01:10 AM   #7
Luvlegs
Luvlegs's Avatar
it restricts the exhaust flow until the engine heats up - like a mechanical choke - at least that's what I've always been led to believe. On all the old cars I had as a kid, that was one of the first things we took off. Then again, we also put on dual exhausts with no cross overs either. If they get too rusty they might stick in the partially closed position. That's about all I can tell you.
"A cat will almost always blink when hit between the eyes with a ball peen hammer"
(you don't always have to state the obvious)
Wear your PPE! You can eat with false teeth but you can't see with a false eye.
1959 Studebaker Silverhawk 350/400
1972 C10 L6 3OTT
2005 F350 - Built - whew!
Luvlegs is offline   Reply With Quote
Old 01-16-2007, 01:35 AM   #8
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Yes that is a heat riser and you can just leave it off after you remove and paint your manifolds but.....remember unless you are putting new pipes on as well that manifold will be a bit shorter with that riser removed. Maybe your exhaust pipe will still reach but maybe it won't. Don't ask how I know
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 01-16-2007, 02:46 AM   #9
GREASEMONKEY72
GREASEMONKEY72's Avatar
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-16-2007, 02:47 AM   #10
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
but don't throw it away. With the constant threat of Cali goin back to the old emission laws and testing procedures... you may need it one day.
Old 01-16-2007, 07:25 AM   #11
Blazer1970
Blazer1970's Avatar
What that does is forces the exhaust to go through the crossover in the intake manifold to the exhaust manifold on the opposite side. This warms the carb and also heats the choke coil spring so that the choke opens properly. That set-up really improves driveability in cold weather.
Blazer1970 is offline   Reply With Quote
Old 01-16-2007, 08:06 PM   #12
OhNoJoe
OhNoJoe's Avatar
If your throwing it out. I'll take it off your hands for a reasonable price
OhNoJoe is offline   Reply With Quote
Old 01-16-2007, 08:17 PM   #13
skokie
skokie's Avatar
Andy I hope not. If I have to get a A.I.R system together then I am screwed. I have only seen 1 of those in the last 2 years. OhNoJoe I am not sure I am going to be getting rid of it here shortly until I know that I wont have to get a longer pipe put on.
68 build thread
Old 01-16-2007, 08:22 PM   #14
1LoC10
Insert Title Here
1LoC10's Avatar
mine was wired open when I bought it
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 01-16-2007, 11:14 PM   #15
PumiceMan
Junior Member
PumiceMan's Avatar
The exhaust on my camaro still has the outside shell, but the flapper had been pulled out of it and the small hole in the sides (where it pivoted) welded up. I assume this was done so the pipes would still fit without modification, and there's less restriction without the flapper in it at all (as oppossed to wiring it open, or removing the spring).
I've since seen than you can buy a spacer and just replace the whole riser - I think there's only 2 sizes, small block and big block. I probably saw them in a camaro parts book - Year One, Classic Industries, Rick's First Gen, something like that. I think they were around $25. The spacers are sometimes called "riser eliminators".
Actually, I just found them in Rick's First Generation - $26.95 for SB or BB.
(Just in case anyone was interested.)
69 GMC Sierra 1500 Custom
68 Camaro SS
18 GMC Sierra SLT
Living the dream
PumiceMan is offline   Reply With Quote
Old 01-16-2007, 11:30 PM   #16
jerry moss
Born Psycho
jerry moss's Avatar
if the pipe won't fit, you can go to your local muffler shop and buy a "heatriser block". before you pitch your current heatriser make sure your manifold is machined to accept a donut gasket--not all manifolds are,some are flat.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
