Old 01-16-2007, 01:12 AM   #1
jlaird
jlaird's Avatar
how to manifold valves
Can anybody explain how to do this with 8 valves. I like the idea of how these setups are clean looking, but never read how to do it.
jlaird is offline   Reply With Quote
Old 01-16-2007, 01:33 AM   #2
jimmydean
jimmydean's Avatar
Re: how to manifold valves
It depends on where you're mounting them. A common practice is to use 4 ports on the side of the tank.
Run a brass nipple from the tank to the fill valve.
Brass nipple from the fill valve to a Tee fitting (I used the Suicide Doors T with gauge fitting), or you could use a street tee and connect it to the output of the fill valve without a nipple.
Nipple on the bottom to the dump valve.
Hose fitting out of the Tee to the bag.
Repeat for each bag.
That is if you are using standard valves. There are "valve manifolds" that are valves integrated into a solid piece that has inputs/outputs on it.
jimmydean is offline   Reply With Quote
Old 01-16-2007, 01:50 AM   #3
jlaird
jlaird's Avatar
Thats what I was talking about. Can that be done with standard valves or does a solid block of aluminum need to be machined?
Old 01-16-2007, 02:03 AM   #4
jimmydean
jimmydean's Avatar
You want something like this? Or do you want to run standard valves?
<edit> they come like this for industrial applications. You can build a solid setup for standard valves using brass too. Just depends on how much work you want to do.
Old 01-16-2007, 02:17 AM   #5
jlaird
jlaird's Avatar
Well, yea, that's exactly what I want but don't have the 750 to spend on it. I was wondering if you can set something up like that with standard valves.
Old 01-16-2007, 02:41 AM   #6
jimmydean
jimmydean's Avatar
Here is how my system is laid out. Each valve pair uses a straight fitting to the fill valve, a nipple to the tee, nipple to the dump valve, and a straight fitting to the bag. I use a u bolt to mount the valve setup to the inside of the frame rail. Mine is a little different that the others because I only had a single output on the tank and I didn't want to try and hang 8 1/2" valves off a single port.
I like the way it turned out because the valves are protected and it leave a lot of room.
Old 01-16-2007, 02:46 AM   #7
jimmydean
jimmydean's Avatar
Also, considering the manifold is all your valves an a lot of fittings, figure 8 1/2" valves are $350, then the fittings are another $100. So building something saves you about $300, but then you have to figure how you want it all laid out. With the manifold, all you run is lines.
Not sure how you set up gauges, I think it has ports for that too.
Old 01-16-2007, 04:37 AM   #8
camaro__thunder
Epoxy Primer Friendly
camaro__thunder's Avatar
contact BILLETIN thats who made my manifold out of aluminum. It cleans everything up especially if you are only running nitrogen bottles and no air tanks.
My Project 69 SWB
SHAVED BAGGED DOORED
camaro__thunder is offline   Reply With Quote
Old 01-16-2007, 09:52 AM   #9
jlaird
jlaird's Avatar
Not too shabby. Got a pic of that thing installed on your truck?
Question for Jimmydean. Shouldnt the water trap be installed between the compressor and the tank? I thought the main purpose of the trap is to keep water out of the tank, and in return, out of your valves?
Old 01-16-2007, 11:54 AM   #10
jimmydean
jimmydean's Avatar
The diagram is a little off. The trap is first, then the check valve.
The water trap is best AFTER the tank because condensation collects in the tank from the compressed air and temp changes. 80% of the water in an air system is created in the tank. So you COULD put a trap between the compressor and the tank, but you will still have a lot of water in your system.
The goal is to protect your valves, not your tank.
Old 01-17-2007, 01:38 PM   #11
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
I think i'm going to disagree here sir. I'd rather have my water trap after the compressor and before the tank. Especially in humid climates such as florida, the comps draw a LOT of condensation in. If my compressors are running a lot, I have to drain my trap every other day. And it's a b!tch to pull my tanks. If they have water in them, they will eventually rust out.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 01-17-2007, 02:25 PM   #12
jlaird
jlaird's Avatar
I was hoping we would get more opinions on this topic. I am still up in the air myself. An argument for putting the trap after the tank is that the compressor is producing warm air that is going to condense anyway once it goes into a lower temp tank. An argument for the trap before the tank is that the compressor is what is taking the air which has moisture in it and putting that into the tank.
I really don't know what i'm talking about, LOL!
Old 01-17-2007, 02:36 PM   #13
jimmydean
jimmydean's Avatar
I have a drain on the bottom of my tank that allows me to drain the water from there. If you just crack the drain, the water comes out first.
You will get more water build up in the tank from the compression of air than you will from the air being drawn in to the compressor.
It is a good idea if you have a lot of humidity to have a water trap before the tank as well. But the fact remains that your tank will have a lot of water in it from the air being compressed. If you don't have a trap between your tank and valves, you will soon have a lot of water in your valves, then in your bags (would that make them water bags?).
If you look at any shop compressor for paint, you will see the water trap between the tank and the gun to keep water out of the paint. Same idea is applied here.
Old 01-17-2007, 03:40 PM   #14
pharcyde05
pharcyde05's Avatar
this in one side the air from tank goes in middle then its up valves front and rear then lines out to bags then out valves i have one of theses on each side of the frame
pharcyde05 is offline   Reply With Quote
Old 01-17-2007, 04:06 PM   #15
jimmydean
jimmydean's Avatar
pharcyde05, so that's a side? If I understand how that's laid out, you have fill/dump on the left and fill/dump on the right and the 90 goes to the bag, correct?
Where did you mount these? I was going to use pipe for mine, but it took up too much space. I had a ton of leakage problems with the drivers rear and that was using machined brass fittings. Did you have any leakage issues with the steel to brass connections?
Old 01-18-2007, 04:02 PM   #16
SlammedDime
SlammedDime's Avatar
67Fleet and jimmydean:
You guys are both correct in a sense. 67Fleet, you obviously have a valid point that if you live in a humid environment, you will get more water droplets as the air is compressed, and thus need the trap before the tank to remove the water/vapor from the air. jimmydean is also correct in stating that you will get water in your tank as the air cools from being compressed, so a trap after the tank is also good.
Most of the valves used in todays air ride, save for the crappy valves that AIM sells, are made for industrial applications and are made to flow all sorts of fluids from air, to water, or oil, or many other non-corrosive substances. Most of the water build up in the air tank is at the bottom of the tank, not the middle where most ports are that are used to feed the valves. Putting a trap between the compressor and the tank will remove some water from the air, but not all of it. Water removed includes water formed from the compression of moist air, as well as the condensation formed by the cooling of the air as it moves through the leader hose.
With all of that said, I do believe its rather pointless, and an added expense that is unnecessary to use traps after the tank, before the valve. Using one between the tank and compressor is sufficient (and depending on climate, not even needed (I don't use one, never have)), and to have a drain on the tank to remove excess water that forms there is sufficient as well to keep the system operating well so the valves don't get screwed up.
67Fleet, if you believe that all of the water collected in your traps is the extent of the water in your system, you are sorely mistaken. If you've never opened up your tanks to drain them, you will be surprised at the amount of water in there (and rust), especially considering your climate.
I'd also like to point out that you can add a product that tractor trailers on the road use in the brake systems called Air Brake Antifreeze. By putting this in your tank (NOT THROUGH THE COMPRESSOR), it will help in eliminating the water in there as well. It is an isopropyl alcohol type substance that will evaporate the water, so to speak.
Matt
Admin @ AirRideTalk.com
Win FREE Viair compressors!
SlammedDime is offline   Reply With Quote
