Old 01-16-2007, 09:18 PM   #1
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
81 SWBSS How much is this worth & lowering ?
I am looking at a 1981 shortbed stepside
305, al intake, edel card, headers, firebird buckets, rust free, never hit, black, runs and looks good
Is it worth 4K?
It was lowered in the front with cut coils and the back by removing leafs. Is this a safe way to drop a truck or just a 1/2 step better than heat wrenching
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 01-16-2007, 09:52 PM   #2
kenm78
Broken Down
kenm78's Avatar
Re: 81 SWBSS How much is this worth & lowering ?
Any Pictures?
kenm78
1982 Chevy 4X4
Project truck
“It’s better to keep your mouth shut and let people wonder about your ignorance, than open your mouth and reveal all doubt”
kenm78 is offline   Reply With Quote
Old 01-16-2007, 10:06 PM   #3
ProStreet68SB
The Engine Whisperer
ProStreet68SB's Avatar
okey dokey heres a picture of the truck.
ProStreet68SB is offline   Reply With Quote
Old 01-16-2007, 10:25 PM   #4
Gary
Gary's Avatar
Working AC? Even with AC I'm thinking 4 large is a bit highish.
Truck in my avatar was $2600, and the lowering job on that truck you're talking about is pretty much the quick and dirty way to do it, have you ridden in it? Probably a bit rough on the ride if that's what was done to lower it (cut coils, removed leafs). Also if you're gonna haul anything you'll be missing those rear leafs. And considering it's just cut coils/removed leafs it sits awfully low, I dunno I'd probably be hesitant.
This is just my opinion.
Gary is offline   Reply With Quote
Old 01-16-2007, 11:22 PM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
If it is truly rust free and everything works like it should that's not a bad price. It's not cheap, but if the paint is in good condition it's still worth it.
If they only cut one coil up front and didn't heat the spring too much when they did it, that's fine. If they got the spring too hot, or cut more than one coil, plan on replacing it sooner or later.
Dixiesys is correct about the rear. If all they did was remove leaves from the spring pack then the rear will be too soft. It may be alright for cruisin but will need to be redone if you ever plan to haul a load.
My suggestion would be to offer 3200 and see what happens.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 01-16-2007, 11:49 PM   #6
84slopwaggin
84slopwaggin's Avatar
Not to jack the thread but Dixiesys how is the stroker doing for you? That is one clean lwb. I'd like to here how it's performing.
84slopwaggin is offline   Reply With Quote
Old 01-17-2007, 01:17 AM   #7
Hoods69BadBowTie
Chevys Kick A$$
Hoods69BadBowTie's Avatar
Sounds a couple hundred to steep to me. I would say somewhere around the low 3,000$ price range for it. I agree if he lowered it and was not careful about the way he did it even though its not a great way you will probably need to spend some money to fix it.
*HOODS is what I answer too*
-'79, '77, '88 Pickup Sold, '85 Camaro, '83 T/A, '81,'83,'90 K5 Blazer All Sold
-'79 3/4 ton "Big Yellow Bananna" Lifted 4spd. 39.5 TSL Swampers, The money Pit
-'86 K5 Blazer Silverado 6.2 4" lift 35"s
-'95 Ext. Cab Shorty 4" Tuff Country rolling 35" M/T's
-'83 Monte Carlo T-Tops. 126,500 Original Miles
-LATER
I would rather push a Chevy then drive a ford!!
Hoods69BadBowTie is offline   Reply With Quote
Old 01-18-2007, 07:58 PM   #8
ProStreet68SB
Ok my dad(1968SWBBigBlock) and I, stopped and looked at the truck yesterday. Turns out. instead of lowering the back by taking a leaf spring out, he just move the shackles until it was as low as he wanted, so theres still a full set of leaf springs there, and it can handle me jumping up and down in the bed. Let me know what you guys think. Got video and pics if you wanna take a look.
pics
Old 01-18-2007, 08:43 PM   #9
Low84
Low84's Avatar
Pretty much what he said. But if the truck is 100% rust free, and I had the money, I could live with myself purchasing it for 4 grand. It looks like a very nice truck.
1978 stepside C10 build: http://67-72chevytrucks.com/vboard/s...d.php?t=468265
Low84 is offline   Reply With Quote
Old 01-18-2007, 11:12 PM   #10
N2TRUX
Happy to be here
N2TRUX's Avatar
Motor sounds healthy. This bothers me though. That door is going to blow up on you sooner or later...
Articles-
"Refining Sierra"
Old 01-18-2007, 11:24 PM   #11
ProStreet68SB
What do you mean by blowup?
Old 01-18-2007, 11:47 PM   #12
bigblock73
yeller
bigblock73's Avatar
Hard to tell by the pic, but it looks like the door seam has been bondo'ed over....and is that a rivit or screw a couple inches up the door?
bigblock73 is offline   Reply With Quote
Old 01-19-2007, 01:07 AM   #13
Gary
Gary's Avatar
Right now it's hobbled with an edelbrock carburetor but it has choke! So it cranks in the cold warnings and will idle by itself in the driveway and warm up while I sit in the warm house drinking coffee. The power loss from swapping from the built to the hilt holley that came with it to an out of the box Edelrbrock 750 cfm was quite noticable, extremely noticable.
Soon as the weather starts warming the Holley is going back on it! With the holley it'd routinely chirp the 1-2 shift and not when I was trying either.
With the factory rear, it has no real launch and just kinda spins and burns up the tire so I can't really flail on it.
I was on the interstate the other night pacing a Vette, I have no CLUE how fast we were going (speedo stops at 85 you know) but we were "well beyond" the 85 and the Vette guy kept looking at me like "wtf are you DOING?? are you CRAZY??" (answer is yes). I esimate we were doing 105-115 and with that 700r4 and the (I believe) 3.08 gears in the rear I was sitting around the 3300 rpm mark doing such insane speeds. Them old trucks get awfully interesting in the triple digits, a bit squirrely...
All in all the motor and tranny I bought from ed455 here on the forums are working excellently just need to get the rear built so both tires grab and get the holley back on it soon as weather permits to really perk it up. As soon as that happens I'll post time slips from the local drag strip (1/8 mile but oh well take what you can get).
Rearend build, carb back on, and then lower it with air bags, 1 piece window kit, and hell I think she's done after that!
Old 01-19-2007, 11:54 AM   #14
ProStreet68SB
The truck has the Scottsdale package on it, and I'm curious as to what that "did" to the truck. Any help would be nice. Keep the replies coming in.
Old 01-19-2007, 07:58 PM   #15
84 400
Sb 400 club
84 400's Avatar
watch for bondo.
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-21-2007, 10:04 AM   #16
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Thumbs up Re: 81 SWBSS How much is this worth & lowering ?
I would offer less than the 4k hes asking say 3k and see where it go's i think the truck is wort that and if you can get it for any amount less than 4k then you got a deal IMO.
If you pass on this truck you will regret it later it's in very good condition and you'll look long and hard to find another one as close to it for the same price.
The Scottsdale package is just an interior and exterior improvement package things like less brite work on the exterior a differant grill and usually manual windowd and locks and plastic door panels without carpet and fabric inserts plastic dash and insturment panels instead of the stainless steel ones stuff like that
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 01-21-2007, 11:30 AM   #17
84slopwaggin
So Dixiesys I guess when you get it bagged and upgrade the suspension and rearend your tags will read VETTEKILLR. Man I love that truck the way it sits. It's my inspiration for aquiring another lwb, which I think I've found. Oh yeah I agree 3K sounds like good price seeing as it looks like a good project truck.
