Old 01-17-2007, 09:46 AM   #1
phlegm
Still Green but learning
phlegm's Avatar
Argh!! Fuel leak
Ok, I have not looked at it yet, but from the back of the cab under the car I have a drip that smells like Gas. I have questions, and I am a Oil changer at best so please bear with me.
1. How is it dripping under the car instead of leaking in the cab?
2. Is it leaking in the cab and I dont know it.
3. How hard is this to fix? JB weld or do I need to buy a new tank assembly.
4. Is it worth it to do a under bed conversion ( I have little to no money right now).
thx
-- Cory
71 Cheyenne 10 - SWB, 350, "3 on the tree" AC cab
07 Suburban LTZ 4x4
2010 Acura TL
98 Mastercraft "FrankenStar" 225
27253 UPS/USPS
IIOY....nope never was
phlegm is offline   Reply With Quote
Old 01-17-2007, 09:59 AM   #2
dave2953
Dave's not here, man
dave2953's Avatar
Re: Argh!! Fuel leak
Could it be that the lines that exit the tank are leaking? It will probably be fairly noticeable once you get a chance to inspect it. The tank conversion seems like it would be a great upgrade, but if funds are limited it may not be an option. I think Blazer tanks will swap between our framerails, but I don't know how much they go for???
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 01-17-2007, 10:01 AM   #3
pkj
on my truck the fuel metal fuel line from the tank comes out at the rear center of the cab. it goes into a short piece of rubber hose. check that first. it may not be your tank leaking. pkj
pkj is offline   Reply With Quote
Old 01-17-2007, 01:39 PM   #4
That is where mine let loose. 30+ years of dry rot and abuse and it finally gave out.
Palf70Step is online now   Reply With Quote
Old 01-17-2007, 02:31 PM   #5
phlegm
phlegm's Avatar
Yep, thats it, had a look at lunch. I thought the fuel line would have been metal all the way to the tank... live and learn. Do I need to empty the tank or is there a way I am not thinking of to change this, any hints?
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 01-17-2007, 02:40 PM   #6
71swb4x4
71swb4x4's Avatar
I am pulling off memory here, but I don't think you need to siphon the tank. I think the fuel line goes up into the corner of the cab above the tank, and then loops back down. It will leak gas when you unhook it, but should only do as much as is in the line up to the upper-most point.
Hopefully someone can back me up on this.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 01-17-2007, 02:59 PM   #7
phlegm
phlegm's Avatar
Mine is about a 2 foot piece under the car, I cant tell the size off hand.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 01-17-2007, 03:07 PM   #8
phlegm
phlegm's Avatar
I think you are correct, at least according to my after market parts manual... aka LMC Catalog
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 01-17-2007, 03:16 PM   #9
chopper103in
chopper103in's Avatar
if the line is full of fuel when you pull the hose off it will act just like siphoning and the gas will come out
when i changed mine i switched it as fast as i could with only a small amount og gas loss
chopper103in is offline   Reply With Quote
Old 01-17-2007, 06:28 PM   #10
phlegm
phlegm's Avatar
Right you are chopper, and that sucked!!
after I got the line off, I realized I had the wrong sized replacement. so I had to let it drain in an oil pan while I went for a 4 gal. washtub (low enough to get under) Then I played move the liquid gold around until it drained. The job was a lot easier then. With Ice coming I just put hte new one on and put the gas back in the truck. I will crank it and check to make sure its done right later.
Thanks everyone for the help, and thanks LMC for showing me what to buy from somewhere else again! lol.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 01-17-2007, 06:31 PM   #11
phlegm
phlegm's Avatar
O yea, and if someone seaches this post later here is what I would have done different. I would have used a pair of vice grips to clamp the center of the line and give me some time to work. I would have worn my eye protection, i didnt get hurt but it easily could have happened. and make sure you have buckets enough to catch gas if needed, and they fit under the truck.
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 01-17-2007, 06:39 PM   #12
john
member #16
john's Avatar
If you unhook the line where it goes in the sending unit that will break the siphon, and you won't lose any gas.
john is offline   Reply With Quote
Old 01-17-2007, 11:09 PM   #13
phlegm
phlegm's Avatar
Doh!
-- Cory
07 Suburban LTZ 4x4
2010 Acura TL
27253 UPS/USPS
Old 01-18-2007, 12:44 AM   #14
chopper103in
now dont i feel stupid
