Old 01-17-2007, 04:11 PM   #1
johnnywagon
Sofa King. We, Todd, Ed.
johnnywagon's Avatar
Dana 60 Front U-bolt Question
Do all front D60's have only one u-bolt on the passenger side with the other 2 mounting bolts threading into the case? Is this a strong set up? Is there a kit or another option to add a u-bolt? I think I found a donor truck and I've always wondered about this. Thanks,
~John
71 Blazer One Ton
65 Chevelle Station Wagon x2
59 Belair 2 Door
71 Chevy Open Road Van RV
www.myspace.com/johnnywagon
johnnywagon is offline   Reply With Quote
Old 01-17-2007, 05:07 PM   #2
Yukon Jack
Post Whore
Yukon Jack's Avatar
Re: Dana 60 Front U-bolt Question
This is a surefire way to identify a Dana 60 but I don't know enough about them to say all Dana 60's use 3 u-bolts and one set of studs.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 01-17-2007, 05:53 PM   #3
Burt4x4
Burt4x4's Avatar
I have seen thoes bolts your talking about getting replaced buy large studs. So you have a nut on top the plate instead of a bolt head. RyanB did this mod at PacificFab in BayArea Calif. Right before this mod he broke both of thoes bolts wheelin at HollisterHills, now it no breky
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 01-18-2007, 02:23 AM   #4
1969 GMC
1969 GMC's Avatar
The only thing you have to watch out for is some Dodge D44's have the exact same setup, with 2 bolts and a u-bolt. But if its a Chevy and its setup like this, its gotta be a D60.
I have seen pics online of someone who actually used a grinder to make a space for a 2nd u-bolt to go, a custom spring plate, and had it run 4 u-bolts like a normal frontend. I think I'd rather do the stud thing that Burt mentioned than this, but it does exist.
1969 GMC K2500
1996 Honda Accord
2007 Kawasaki KLR 650
1969 GMC is offline   Reply With Quote
Old 01-18-2007, 01:33 PM   #5
johnnywagon
Thanks guys. Now I just have to decide if I want to drop $1500 on a 87 crew cab w/blown engine. I've seen better deals, but they just come 'round very often any more. I've always planned on scoring a 1-ton pickup, putting the front Dana 60 in my Blazer (w/crossover steering) and then putting the 3/4 ton Dana 44 from the Blazer back into the pickup. Then I'd have a pickup for going to the dump, etc.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-18-2007, 02:17 PM   #6
1969 GMC
1969 GMC's Avatar
That doesn't sound like a bad deal, but there are probably betters out there. 2 weeks ago I passed on a '77 K30 350/TH400/NP203/D60/D70HD for $1200, ran down the road great. May I recommend car auctions (not e-bay, real time)? There seem to be quite a few of them around here, and there can be a lot of screaming deals to be had.
My 2cents.
1969 GMC K2500
1996 Honda Accord
Old 01-18-2007, 03:00 PM   #7
johnnywagon
Theres a pretty savvy bunch of hard core 4x4 guys around here and whenever a D60 or a complete truck comes up for sale, they usually dont last long. In fact, I found two 1-ton trucks last year that the front D60 had already been swapped w/D44s. I know of a complete running truck 500 miles away in Montana for less. Its just that the timing is good with this rig BUT I think I might have to reconsider because you're right, there are better deals.
~John
71 Blazer One Ton
59 Belair 2 Door
Old 01-18-2007, 11:31 PM   #8
1tonswb
1tonswb's Avatar
Thats so true! I snag every cheap 1 ton that I can find. Im usually trying to get them before my friends find out about it (lol).
1tonswb is offline   Reply With Quote
Old 01-19-2007, 01:14 AM   #9
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
1500 is around the going rate for just an axle these days, kind of $$$ for me.
this guy is from pirate 4x4 and is very very reasonable, 90% of his axles are $8-900 and he ships every where.
www.extremeaxlesales.com
trkklr77 is offline   Reply With Quote
