Old 01-17-2007, 05:08 PM   #1
1ST BUILD
suspension compatability
let me say first what a great find this site is !!! A wealth of talented craftsmen shareing their time & trade knowledge , gold !!!
Im starting a build on a 70 stepside , just got the frame back . combo will be a 502 , 400 w/ gear vendors , 9" rear , and big meats ( a step side needs big tires ! ) Question is , are air bags compatable with this set up . will a drop member and notched 4 link rear hold up ? Can you lay frame and still take it to the track ? or are these 2 different worlds . Thanks for any help and guidance, this is my first build .
1ST BUILD is offline   Reply With Quote
Old 01-17-2007, 05:20 PM   #2
jimmydean
jimmydean's Avatar
Re: suspension compatability
Welcome to the board!
I don't see why laying out would affect track performance. I know bags can handle a great deal of power based on some of the other discussions that have happened.
I think you might be compromising your track performance, but if done right, there shouldn't be any issues.
jimmydean is offline   Reply With Quote
Old 01-17-2007, 06:01 PM   #3
1ST BUILD
my only concern is saftey . Cutting up the rear section , then applying a high torque load raises some concerns. I know they do in crafting a drag set up , but thats with the torsional ridigity of a full cage .
Old 01-17-2007, 06:10 PM   #4
jimmydean
jimmydean's Avatar
As I understand it (and someone like Porterbuilt would have more info) the torque would be applied to the frame where the 4 link attaches, not to the step notch. As long as that is properly braced, it should be fine.
I don't want to do something like a step notch because my rig is used for towing. But for HP, I would think you'd be fine as long as the frame and links are designed to handle it.
Old 01-17-2007, 07:11 PM   #5
pkj
thought there was some talk one time about some of these race tracks had a "bags no drag" rule. just something i read somewhere.
pkj is offline   Reply With Quote
Old 01-18-2007, 03:57 PM   #6
craig@ridetech.com
Formerly LSC71
I've discussed this with others before and I think the main concern for most tracks is the ability to adjust the suspension while you are driving down the track, if you can convince them that it isn't something you can/will do then you should be fine. The fact that it is an adjustable suspension shouldn't even come into play since almost every set of coilovers is adjustable. Like I've said before we have several guys that run drag cars with air bags and they have not been denied a race. All in all I'm sure it just comes down to the track and their rules, ultimately they have the final say so.
craig@ridetech.com is offline   Reply With Quote
Old 01-18-2007, 10:07 PM   #7
PBFAB.COM
PBFAB.COM's Avatar
First Build-
If done properly, there will be no structural issue that effect the desired outcome you are going for... frame-laying drag-truck. The torque will be transferred to the chassis where the four-link attaches. If you use a panhard bar to locate the axle, the mounting points will need to be sufficient to handle the forces it generates.
The one recommendation would be that you don't really try to plant the frame-rails on the ground (an inch or so away would be best... it could be nasty if you had a bag failure on the strip and layed-out doing 100mph).
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 01-18-2007, 10:40 PM   #8
jimmydean
jimmydean's Avatar
Originally Posted by porterbuilt View Post
First Build-
But if he was to mount titanium drag blocks to the frame rails, think of the light show!!!
Old 01-19-2007, 12:59 PM   #9
1ST BUILD
Good advise . Im into my 3rd motor in my 70 GTO , I enjoy rebuildin em just ( almost ) as much as runnin it hard . I just dont want to build a truck I have to baby , or worry about . Any build threads with good examples of a suitable setup ? FNLOW 's looks like a smooth ride with those long bars . Thanks , ive been ckn out some AWESUM work in these threads .
