Old 01-17-2007, 08:17 PM   #1
BigFishBobby
Freakin' Short
I think my dome light is the culprit. I have had the problem for over a month, but the other day the dome light stopped working. Question is this, how is the dome light wire likely routed to get back to the fuse box? I can see it at the light fixture, but don't know where it eventually comes out at so I can just change the wire out. Secondly, if that is my short, is changing the wire going to fix the problem? Thanks for the input.
BigFishBobby is offline   Reply With Quote
Old 01-17-2007, 08:42 PM   #2
72lb4x4
Re: Freakin' Short
More than likely it snakes above the back window, down the driver's side in the back, runs up to the front along the floor where the inner and outer rockers meet. Then on to the fuse box, or the headlight switch.
If it plugs into the fuse box, you can unplug it there.
According to my 72 manual there are 2 wires, a green and a white.
72lb4x4 is offline   Reply With Quote
Old 01-17-2007, 08:44 PM   #3
JimKshortstep4x4
Re: Freakin' Short
The wiring for the dome light is routed through the left upper rear cab corner down beside the gas tank and into a channel covered up by the step plate. From there it goes into the fuse panel. You will want to look for a bare wire in the wiring.
Jim
Old 01-17-2007, 08:46 PM   #4
onetonk5
Cereal Killer
onetonk5's Avatar
Re: Freakin' Short
anyone know how the wiring for door pin switches is routed??
onetonk5 is offline   Reply With Quote
Old 01-18-2007, 12:07 PM   #5
BigFishBobby
Re: Freakin' Short
Ok, so I figured out why the dome light was not working. It came unplugged from the fuse box. So obviously taht is not my short (even though I did find a couple bad spots in the wiring that will be replaced). Is there a likely culprit here? Should I just start replacing wires to the lighter, etc.?
I dont think my short is in the radio or dome light. Where else are the common shorts located? Thanks.
Old 01-18-2007, 12:16 PM   #6
FarmTruk
In Memoriam...
FarmTruk's Avatar
Re: Freakin' Short
This looks like a likely candidate for a short...my rocker...
'68 C10 SWB 307ci 2BBL
FarmTruk Pics Here
"You know, doing what is right is easy. The problem is knowing what is right."
FarmTruk is offline   Reply With Quote
Old 01-18-2007, 03:56 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Freakin' Short
check yout tail lights and turn signals and brakes. It's been a couple months, but if I remember right, the dome light is on the same circuit as the parking lights and brake lights. If I am right, then the very first place I would look, is under the rear bumper for hillbilly engeneered trailer lights.
