QuadraJet Edelbrock or Holley ????
What is everyones thoughts on carburators....... My '72 Super Cheyenne has a quadrajet on it and it needs rebuilt. Should I have it rebuilt or put on a different one. Let me know what you think ............
Thanks Harmsy ![]() |
Junior Member
Re: QuadraJet Edelbrock or Holley ????
I'm a Holley man myself,just because the simplisity.Holley carb and edel. intake.Great looking truck btw
sweet truck....well i am guessing your intake is a spreadbore with a q-jet.
unless your going to use adaptors or change the intake..rebuild the q-jet.. autozone has them rebuilt for 130.00 (devorced choke type) SWEET TRUCK YOU CAN UPGRADE NOW TO... heres the hot tube choke q-jet. i converted to electirc choke on my truck one pump and a click..and were driving Last edited by rage'nrat638; 07-12-2007 at 06:59 AM. |
Alright Alright Alright
I have your identical truck (orange and white 72 cheyenne). i would go with the quadrajet. its the best in performance and economy not to mention....a direct replacement.
1972 Cheyenne Chevrolet red and white 357ci, Vortec heads, GM Performance high rise intake, Comp 268H .454/.454 218/218 110 LSA Quadrajet carb, Flowtech headers, 2.25 40 series HEI, Curve kit, TH 350, 3.07 gears 275/60/15s on 15x8 rallies Last edited by crm318; 01-17-2007 at 10:41 PM. |
Happy Camper
I run Edelbrock on Edelbrock... love it
RIP El Jay! Love you brother! |
To The Levy
rochester would be my choice, if your throttle shaft isnt worn, rebuild it and go with it, holleys in my eyes tend to run rich and should have the power valve saver check ball installed, edelbrock would be second choice ,holley being last, my opinion only
with a nice truck like that id go with a holley
67 chevy c 10 2x4 350/700r4 short/fleet 90 Chevy 1500 4x4 350/5 spd short/fleet 90 Chevy 454 ss 93 chevy camaro z28 auto t-tops 2013 Chevy Silverado LT CCSB 4x4 |
If you have the Original quadrajet and it's rebuildable (throttle shafts in good condition, etc.) I would say rebuild it yourself. DO NOT BUY A REBUILT CARBURETOR FROM AUTOZONE, NAPA, O'REILLY, OR WHATEVER PARTS STORE YOU HAVE IN YOUR AREA. Mass produced rebuilt carburetors are junk no matter where you get it. If you decide to take your chances and go this route, at least hold on to your old carburetor for a while before you turn the core in; that way you have your orignial to rebuild after you put 4 or 5 rebuilt ones on and finally get tired of that.
If you don't want to rebuild it and don't know a good carburetor man, Edelbrock makes a quadrajet replacement that even looks like an original quadrajet. They are brand new but can be pretty expensive. I've got a 600 cfm Holley square flange carburetor with Electric choke, on an Edelbrock Performer manifold on my truck and I'm real happy with it. My truck did not have the original carb on it when I bought it so that was not an option for me. The edelbrock performer carburetor is a good, simple, reliable carburetor too, but I'd probably go with a Holley over one of those. Or you could convert it to Tuned Port Injection and be done with it! Last edited by kevenj; 01-17-2007 at 11:57 PM. |
I am running an Edelbrock carb on a Edelbrock intake. I would have rebuilt the q-jet, but didn't have the time/patience to do so.
70 GMC 1500 2wd lwb 00 Chevy 2500 |
![]() Join Date: Jan 2006
using a stage 2 jet quadrajet out of summit and performer rpm intake.
qjets are awesome but not alot of people seem to make them work well. I agree do not buy a rebuilt as they are crap. I would try the edelbrock qjet ( i havent tried one yet) unless you can rebuild it yourself. If you have a little time and want to learn, buy the rochester book and you will know everything about carbs and qjets, it is well worth the time.
My Holley Street Avenger on the Performer intake works great. And most new Holley's come with power valve blowout protection now.
Jay
You only need two tools in life - WD-40 and Duct Tape. If it doesn't move and should, use the WD-40. If it shouldn't move and does, use the duct tape. If a hammer doesn't fix it, you have an electrical problem! Slot Cars, 1:24 Scale, 100MPH@100,000RPM, fastest things on wheels! ![]() |
#13 |
Too many projects
I personally rebuilt my Q-jet a few years before I replaced the motor (& went to an aluminum intake). I believe a kit was $10 at the parts store. I did it according to the instructions and it ran great afterwards. (First time I ever rebuilt a carb and it was simple.)
Andrew 84 GMC C1500 SWB 6.2 Diesel/700R4/3.42 "Grandpa's odd duck" |
#14 |
laying low
![]() Join Date: Mar 2001
Honestly there is not much to a qjet to get wrong. Read the instructions and clean it real good and put it on, set it and leave it alone. Constant tuning is not necessary with a qjet. Great carbs and better mileage too with those small primaries.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
#15 |
Q-Jets are easy to rebuild and i've been told that they are the next best thing to fuel injection when tuned right. If not the Q-Jet, then Edelbrock.......
1997 GMC Sierra Ext 1965 Mustang |
#16 |
Aluminum slot wheels rule...
I vote holley. They take some adjusting, but when set up right, they kick @ss. Best 250 bucks i ever spent was to buy the 500 holley for my truck.
#17 |
blood type; Retumbo
when I upgraded to a SBC I used the 1979 4MV that came with it. my neighbor had an original 72 Qjet from his old truck but they didnt have elec. choke. I recalibrated mine to the 72 specs and it works wonderful.
(I had to go elec. choke due to lack of EFE valve with headers.) |
#18 |
Rebuild the q-jet. Kits aren't expensive, and you learn something in the process. I rebuilt my Holley and it was pretty staight forward. I would have to make adjustments when the weather turned cold tho'. It would tend to run rich in the winter.(especially when I would forget to let off on the manuel choke,DOH !!)
