Who's in CHARGE??????????
more on Large Marge
here's a couple more pic on Marge's progress. the caption on the pic's pretty must tell's ya the story.
i'm using a FWD steering column along w/the cable shifter in conjuction w/the modified cross rod linkage from the Caddy && the stock 48 chevy pedal assembly thats been modified to mount a 87 Chev 3/4ton PU MC & Booster on it &&& that is bolted to the S10 frame near where the trans crossmember was bolted. cross bar w/cable hooked up to it cable bracket on pedal assembly Brake Booster Clearance. MC & Booster Master Cylinder Clearance MC Clearance & this is w/o the pads between the body & frame Column Cable Shifter is in w/another brace to be added soon, it will rap around the lower part of the column down to the cable. didnt think i'd ever get this done. if by some chance the pics dont come up for u, click on Large Marge below & go to the last page...joe
Send a card to a soldier in Iraq My Music PlayList Large Marge Donate Blood,Plasma,Platelets & sign your DONORS CARD & SAVE a LIFE |
![]() Join Date: Apr 2005
Re: more on Large Marge
What make and year of car did the column come out of? Thanks,
Rob
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#3 | |
came out of a 93-94 Buick Park Ave. BUT i used the cable from a mid 90's chevy lumina van(because thats what i "was" going to use until i found out the column was junk), BUT i believe the cables are the same lenght...joe
