Sierra Grande Club
Making preparations to pull motor.
I decided to pull the motor on my 71 to replace the pan gasket (pan is loose, but can’t get it out). I will need to jack up the block to get the pan off which requires the mounts to be undone anyway….the motor mounts need changing too.
So I would like a list of do’s and don’ts and any tricks to help me out. I never pulled a American engine before so not too sure what to do. Thanks, s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() |
Re: Making preparations to pull motor.
drain antifreeze
pull radiator remove fan assy disconnect all hoses disconnect battery remove carb linkage remove carb... install lift plate disconnect all wiring hei, starter, etc disconnect alt bracket and swing to the left lower inner fender remove bellhousing bolts remove flex plate bolts slide converter all the way back inside trans. support trans with jack remove engine mount bolts connect lift to lift plate on intake [ pull it out] ![]() ![]() ![]() ![]() |
its all about the +6 inches
digi photos will help on the vac lines, and bracket locations... or poor art work (drawings) will do if there's no digi cam.
Mark, you forgot to pull the hood! fan shroud needs to come off if you still have it Disconnect the fuel line at the fuel pump, the frame side of the line. If you don't have a carb lift plate, then no need to buy one. They are nice, but not needed. If you have power steering, unbolt it from the engine, and flop it over on the frame... same for a/c stuff If the engine is original and unmolested, then there are ground straps on the valve covers to firewall, unbolt them take your time, tripple check everything. Lift the motor a few inches, then look at everything again. |
Saving 1 truck at a time!
Run and gun!
Take no prisoners! No pain, no gain! Don't take no for an answer! Don't shoot till you see the whites of their eyes, and Aim for the heart...sometimes they charge when they're wounded! Oh yeah...righty tighty, lefty loosey. Keep your cell phone handy and programmed for 911! If you buddies come over to help...DON'T let them drink!
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
ENGINE HOIST: a tool for testing the tensile strength of everything you forgot to unhook.
good luck!!
-1947 3100 -1968 C10 -1970 K20 |
Nothings as cool as my 72
A good point is to mark the hood and hood hinges where they line up so for when you reinstall you dont have to mess around with alignment.
1972 C10 Longbox In the middle of body off restoration Rebuilt 355, turbo 400, 3.42 12-bolt Rolling chassis finally done and cab mounted. Now onto sanding, bondo and more sanding. ![]() |
Disconnect your headers or your exhaust manifolds also.
RIP Mr Ron
![]() Join Date: Dec 2005
How many members have their trucks scattered all over the garage that started out to tighten the fan belt. Take pictures, it might be the last time you see it in one piece.
Ron (Mr Round Tuit) ![]() Be kinder than necessary, for everyone you meet is fighting some kind of battle TN Message Forum TN Facebook Group SETN Truck Show My Photobucket |
Weekend Warrior
Shouldn't have to pull the hood if the radiator is out. Have a buddy/kid/wife "ush the hood a little further up with a broom handle or get a 2x4 to hold it up a little higher - there is a little more room these old hinges flex around alot.
Make sure that you get the motor hoise hook/chain as tight as possible to give you the most clearance. I pulled a V8 out of my 4x4 without taking out the Radiator or Pulling the hood. Just have to know how to angle the motor around. These trucks have an airport under the hood. You can basically spin the motor around 360 in there. Good Luck ![]()
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() Last edited by arkracing; 01-18-2007 at 10:41 AM. |
![]() Join Date: Mar 2004
I’m doing this right now my engine goes back in tomorrow I edited rage's post to add stuff and change the order, as it's pretty important that it's done in a certain order. "Example: removing bell housing bolts before the flex plate bolts is dangerous to both you and the trans."
remove hood----- mark placement can be done without but it's a PITA. Disconnect battery Drain antifreeze Remove fan and shroud Pull radiator Disconnect all hoses Remove carb linkage Remove kick down cable Remove ground straps including negative battery cable to engine block Disconnect wires to -Distributor -Alternator -Oil pressure sensor -Water temp sensor -Choke ------Skip if you don't have A/C------ Remove trigger wire on compressor Remove compressor-mounting bolts DO NOT REMOVE HOSES Remove any brackets holding hoses to engine and pull compressor with the hoses still attached to the side. Secure with a bunggy cord or wire coat hanger to keep it out of the way. ------Skip if you don't have A/C------ Remove starter Remove tork converter cover Remove flex plate bolts Slide converter all the way back inside trans Remove exhaust from manifolds Remove bell-housing bolts Support trans with jack Connect engine lift to lift plate/chain on engine put enough pressure to take out the slack but not enough to lift engine <safety thing Remove engine mount bolts Lift engine [ pull it out] ondrew ps. i've done probably 20+ engine R&R's and SBC's are the easiest so don't worry about it. |
#11 | |
NOT REALLY BANNED!
![]() Join Date: Jul 2004
HAHAHA! I took my motor out to rebuild it. That turned into: TH400 swap Tubular mounts Power brakes Power Steering 68 Frontend swap Wheels and tires And guess what? Motor still isnt in the truck yet. ![]() ![]() ![]()
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
I'm leaving mine's in and just building one to replace it
#13 |
I would get all the grease off it before I started taking stuff off,put on some degreaser and get all the grease off,powerwasher is helpfull
#14 |
Eat My Rust
#15 |
Sierra Grande Club
Thanks everyone for all the good suggestions, I’ll have this list handy this weekend when I lift the motor out!
s/t
#16 |
If you have a steel line for your oil pressure (as original) do not forget to unhook it. It will make a hell of a mess if you forget that one thing and don't unhook it.
I am a proud member of the "No, it's not for sale, I'm gonna fix it up someday" club. |
#17 |
Junior Member
If you've pulled non-american engines before (i.e front drive imports?) This will be a breeze.
_______________________________________ 62 SWB BBW (under construction) 86 Vette Convertible |
#18 | |
Sierra Grande Club
This is looking good. ![]() s/t
#19 |
Sierra Grande Club
I’m thinking of pulling my exhaust manifolds off and doing a test fit of the headers to double check fitment. If I pull my manifolds off, can they be reinstalled with out any issues?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe. ![]() Last edited by Sport/Truck; 01-20-2007 at 05:03 PM. |
#20 |
I like unbolting the manifolds, and leaving them on the pipes in the engine compartment. Makes dropping the engine in easier. Instead of worrying about the pipes goinf up in the right area surrounded by the studs, you just drop the engine in and worry about the motor mounts.
#21 |
Sierra Grande Club
Thanks, but I want to undo everything to test fit the headers anyway. Broke off one stud on the down pipe. I’m now starting to remove the manifolds. After the test fit the only thing is left is motor mounts then pull it out.
s/t
