Old 01-18-2007, 09:54 PM   #1
cochino12
It followed me home?
cochino12's Avatar
best/easiest way to pull front clip
So I found a front clip from a 91 burb as well as a set of power doors w/pw mirrors for my 80, best part is the lady only wants $200!!! Anyway it's been damn cold here and the burb is outside and I've never pulled a front clip all at once. Does anybody have any advice on how to get the front clip and doors off fast enough so I dont freeze.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 01-18-2007, 10:05 PM   #2
82c10
needin' money
Re: best/easiest way to pull front clip
wear a coat, just remember where all the bolts are, and shoot some pb blaster or something on them like the day before you go to get them off
SWB Stands for Short Wide Bed
82c10 is offline   Reply With Quote
Old 01-19-2007, 06:07 AM   #3
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Lightbulb Re: best/easiest way to pull front clip
Well there really isn't any "Fast" way to do it especially when it's cold out but i'd start with the doors first unhook all wiring and just unbolt them from the hindges.
Then that will give you full access to the front clip bolts in the door jambs but don't remove them yet then remove the hood then undo the hood release cable then disconnect the front clip wiring harness at the fuse block unhook any groung straps that may be attached to the frame and unhook the radiator hoses and tranny lines unhook any airconditioning hoses that go the the evaparator unhook the battery cables and remove the battery and disconnect any other odds and ends like vacuume lines and shuch and unbolt the core support bolts and then remove all front fender bolts and you should be able to lift the clip off the front of the truck bring a few friends and stay warm
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
