Well I decided to put a block heater on my 69 3/4 ton because she has a really hard time starting in subzero temperatures. The question I have is...what size are the expansion plugs on a 350?
![]() Josh |
Re: Expansion (freeze plug) question
If I remember correctly they are 1 1/2" but it's been a while; Your local NAPA store can look up the correct block heater by application or I'll check and post it here tomorrow when I'm at work. It's also important to install it in the right location on the block. I know it's on the left side and I'm pretty sure it replaces the rear freeze plug on the left side. I'll check that as well.
![]() Join Date: Mar 2003
They are 1 5/8''
#4 | |
Napa part number for block heater is 605-1490. Should be installed in the left rear expansion plug hole (driver side). The element should be oriented at 12:00 (pointing straight up). Hope this helps. |
~Rest In Peace~
1 5/8
is it fast ? it has a lighting bolt donut? B___H please, I can remove 90% of your so called "beauty" with a kleenex |
Appreciate it guys!!!
![]() Join Date: Dec 2006
This one doesn't use no stinkin freeze-plugs:
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. Last edited by WorkinLonghorn; 01-19-2007 at 10:10 PM. |
