Old 01-19-2007, 04:24 AM   #1
454_72_4X4
454_72_4X4's Avatar
SM465 inspection help
I have a SM465 4 speed trans I'd like to remove the top cover and check out the internals.
Is there a specific gear I have to have the trans in so the cover will come off?
72 C20 4X4 454 4 speed
89 Trans Am (was) 305 TPI 700r4
93 C1500 2wd Extended cab 350 700r4
98 Sonoma (TPI outa the Trans Am)
03 Yamaha 660 Raptor
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
454_72_4X4 is offline   Reply With Quote
Old 01-19-2007, 07:23 AM   #2
Blazer1970
Blazer1970's Avatar
Re: SM465 inspection help
It has to be halfway into reverse in order for the reverse shift fork to clear the gears on the main shaft.
Blazer1970 is offline   Reply With Quote
Old 01-19-2007, 09:02 AM   #3
68C15
blood type; Retumbo
68C15's Avatar
why do you need to check the internals?
68C15 is offline   Reply With Quote
Old 01-19-2007, 03:24 PM   #4
454_72_4X4
454_72_4X4's Avatar
Thanks Blazer!
I figured there was some position or sequence to getting the cover off.
Curiosity more than anything right now, but if I decide to use this trans or sell it I feel more comfortable at least knowing what it looks like inside.
03/04 660 Raptor
07 700 Raptor
85 Honda Odyssey
