Old 01-19-2007, 07:57 AM   #1
mvpco
Rear Air Conditioning hose needed
HI All!
I am looking for the Rear Air Conditioning hose that goes from front to back, the Burb I am getting has a leak in the hose, the owner says. Any Ideas? I looked in LMC and nothing listed
Jeff Smith
Pensacola, FL
mvpco is offline   Reply With Quote
Old 01-19-2007, 09:58 AM   #2
olblue60@aol.com
member
Re: Rear Air Conditioning hose needed
check out some of the aftermarket air companies. they have hose and fittings to create your own.
1967 C/K10 Chevy Panel
1968 C/K20 Chevy Pickup
1968 C/K10 Chevy Suburban
1941 Chevy Sedan Delivery
1960 Chevy Sedan Delivery
1972 Camaro SS 396 #s matching
1971 Harley FX Superglide
olblue60@aol.com is offline   Reply With Quote
Old 01-19-2007, 10:02 AM   #3
mvpco
Great , Thanks!!!
Jeff
Old 01-19-2007, 10:19 AM   #4
JimKshortstep4x4
I had the front to rear hoses made up at a truck refrigeration company in Grand Rapids, MI. I took my old hoses in and they used matching thread connectors with the the hydraulically clamped ends to make up new hoses. (To get away from the original hose clamps which tend to leak with R-134A). I would suggest replacing both hoses while you are at it.
If you want information on the company that I used, let me know and I will post the contact information.
Jim
Old 01-19-2007, 12:36 PM   #5
mvpco
Yes please, send info.
also was it a major undertaking to replace them
Jeff
Old 01-19-2007, 08:18 PM   #6
JimKshortstep4x4
The name of the company that made the hoses for me is:
Thermo King
955 76th Street. S.W.
Byron Center, MI 49315 (just south of Grand Rapids, MI)
Tel. No. 1 800 968-9378 Ext.625
They have done several jobs for me and the work has been excellent.
I am still in the process of hooking up the hoses as this was part of a frame off restoration. So far it has been quite a bit of work as you need help to feed the hoses from rear to front.
The assembly manual has some excellent pictures of the routing in it.
Jim
Old 01-19-2007, 09:12 PM   #7
stsalvage
Scrapper 1
stsalvage's Avatar
Remmber 1973--1987 chevy 4 door suburbans used that same rear air condioning system as well Gm might still make the part
stsalvage is offline   Reply With Quote
