Old 01-19-2007, 08:05 PM   #1
Southedisto
River life......
Southedisto's Avatar
Pulley alignment problems
While converting to PS, I realized that neither pulley I have will work. So which crank pulley do I need. If someone has a pic, or the pulley I need, please post up. Here are the pics of my problem, shallow and deep pulley.
Also, would the brackets make any difference? I have two sets of those also, both of them different. One is cast, and one is stamped, all help is greatly appreciated.
Southedisto is offline   Reply With Quote
Old 01-19-2007, 08:14 PM   #2
69TowRig
Re: Pulley alignment problems
Just went through this, and Joey67 did too. You have a short water pump. That 2nd pulley is a short water pump PS pulley. You will need either a 3 or 4 groove crank pulley for short water pump to make that work. The short pump crank pulleys fit flush to the harmonic balancer. This is using the cast brackets.
After playing around in the WTB section for over a week I called summit and ordered their 3-groove chrome crank pulley P/N SUM-G3972. It should arrive mid-week and I will report back if it fits or not, but I am pretty confident that it will work great.
-Chris
Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid.
Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals...
69TowRig is offline   Reply With Quote
Old 01-19-2007, 09:25 PM   #3
rage'nrat638
rage'nrat638's Avatar
heres a picture
mines a double cast crank pulley and a double rear pulley
rage'nrat638 is offline   Reply With Quote
Old 01-19-2007, 11:29 PM   #4
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
I’ll make note of the crank pulley as I don’t think my pulley issues are solved yet.
Thanks for the PN#.
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-20-2007, 01:22 PM   #5
Southedisto
River life......
Would a later model work?
Old 01-20-2007, 01:31 PM   #6
ratrod67
ratrod67's Avatar
Up to 72 will work unless you can find one from a corvette or 1 ton truck. 73 and up used the long water pump set-up. Mine is a double crank pulley with a single add on for the power steering.
ratrod67 is offline   Reply With Quote
Old 01-20-2007, 01:41 PM   #7
Southedisto
River life......
Originally Posted by ratrod67 View Post
Up to 72 will work unless you can find one from a corvette or 1 ton truck. Mine is a double crank pulley with a single add on for the power steering.
I have read that a dozen times since last night, guess I'm getting desperate . Thanks for the reality slap
Old 01-20-2007, 03:34 PM   #8
red71cheyenne
Back in the sticks
red71cheyenne's Avatar
I had the same issues installing power on the Blazer, and just bought 3/8 inch spacers from the hardware store to move the pulley out far enough to reach. Had to also get the proper pulley used from a board member as I didn't have the right one. Looks like the deep one in your pic.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection
1969 K5 Blazer w/Tuned Port
2010 2SS/RS Flaming Orange Camaro
2011 K1500 Suburban
2014 K1500 Pickup
2008 Nissan Altima? The wifes' hoopty
red71cheyenne is offline   Reply With Quote
Old 01-20-2007, 04:43 PM   #9
Sport/Truck
Sierra Grande Club
You guys should contact this guy SouthernParts he has pulleys for $10 & are for the short water pump. I ordered a water pump pulley and got it the other day. Now I’m waiting to see how everything looks after I get the truck back together. I may need a crank pulley before it’s over.
s/t
Old 01-20-2007, 07:01 PM   #10
TraderJon
TraderJon's Avatar
i know how you feel,I just went thru the same when doing the bbc swap,between my two buckets of pulleys & my buddies two buckets,i managed to scrape up a set off of a 81 3/4 ton truck,,,I had to buy a new p.s. pump from O'rielly's & i think Ragenrat gave me the part #'s for the p.s. brackets,thanks Mark !,,,Good luck..
Jon
TraderJon is offline   Reply With Quote
Old 01-28-2007, 02:43 AM   #11
69TowRig
Well as it turned out, that particular pulley is the wrong diameter for my application (I should have drove the hour round trip to measure the pulley where the truck is stored). The original was a 6 3/4" and that Summit pulley is a 7 1/4", so it contacts the water pump pulley and won't work. Ugh now I have to send it back to Summit and cough up even more money for the smaller diameter one.
-Chris
