01-19-2007, 10:54 PM | #1 |
Power Steering problem need input!
Ok I just got my 70 LWB running and went for a quick drive and the power steering does not really work. The res. is full and I flushed out the system but the fluid still foams up and the pump makes a winning sound. Their is very little steering help comming from the system. If I rev it a bit it will kick in but the pump is screaming. Now I know nothing about this truck as I just got it, and it was not running but their was another steering box in the bed. Any ideas as to the pump or box?
Kevin LFD Inc. |
01-19-2007, 11:14 PM | #2 | |||
Union Electrician
Re: Power Steering problem need input!
Sounds like air in the system to me. I put PS on my 69 in my avatar and it did the exact same thing. I had to turn it by hand with the cap loose and it belched a few times and the pump stopped whining and all was well
. my .02
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5" Help support the board->HERE Board vendors -> Vendors list Zip:40272 Big Sandy Survivor... Quote:
01-19-2007, 11:17 PM | #3 |
My vote is the pump.
I thought this was a very informative read on PS pumps: http://www.thirdgen.org/noises-power-steering-pump
-Chris Building a stripper, one part at a time: 1969 K5, 307, 3spd, 3 seats, hard top. Added Pwr Discs, Pwr Steering, Aux Battery, T-case Skid, Lighted Sidemarkers, HEI, Lock-Right Diff, ECE Class IV Hitch, 32" MT/Rs. Parts to Install: Hand Throttle, Console, Tow Hooks, Dual Horns, AM-FM, Dealer Swing-Away Tire Carrier, Gas Tank Skid. Also building a 1950 Willys CJ-3A and off-roading a 2001 Nissan Frontier on 1-Ton Portals... |
01-19-2007, 11:20 PM | #4 |
Active Member
Id put the front on stands, run the motor, and turn the wheel lock to lock quite a few more times, it sounds like there's still a bunch of air in the system. It seems someone here had the same prob a month or so back and this fixed it.
Found the linkhttp://67-72chevytrucks.com/vboard/s...d.php?t=222223
Never try to teach a pig to sing; it wastes your time and annoys the pig! Gets More Chicks My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". Last edited by GMCMAX; 01-19-2007 at 11:37 PM. |
01-19-2007, 11:29 PM | #5 |
When I put hydro assist on my K5 I had to turn it lock to lock with the front tires off the ground about 15 times to get all the air out.
Project Family Values Build Thread Vehicles/Projects: -1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon... Pleasure in the job puts perfection in the work. -Aristotle |
01-19-2007, 11:39 PM | #6 |
Outlandish Trends - FL
That was me 2 weeks ago. Put it up on stands and rolled the wheel back and forth about 20 times, re-fill reservoir, cycle the wheel 20 more times, rinse, repeat. All was well after a few of those.
-Bret 67 short-fleet sold! |
01-20-2007, 12:01 AM | #7 |
A-Adam A-Adam
Air
70 3/4 ton GMC Camper Special |
01-20-2007, 12:12 AM | #8 |
Sounds like the PS fluid is all foamy. Jack stands as above and let sit overnight.
Good luck - Bob
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
01-20-2007, 01:44 AM | #9 |
been there, done that.
01-20-2007, 02:05 AM | #10 |
Sorry I was in a hurry before, here is the whole story. When we loaded it on the trailer last weekend it was puking fluid out the vent hole in the cap every time we turned the steering wheel. Got it home and I noticed the return line was soft and buldging (wrong kind of hose) so I replaced it and flushed the system at that time. Once I got it running I turned the wheel and it puked all over again. I jacked the front up and with the motor off I cycled the steering for a few minutes then fired it up and did the same. Topped off the fluid and it has been sitting for 5days untill tonight when I had enough junk moved out of the way for its maden voyage. It was cut short when the steering just was not their. The sound the pump was making (only when trying to force it to turn) is just like if the wheel is bound up against the curb and you keep trying to turn the wheel. I don't mind buying a pump but I just don't want to do it and not have that be the problem.
Kevin LFD Inc. |
01-20-2007, 07:10 AM | #11 |
WTB this ad
Sounds like you need a pump. My C10 didn't have problems until after I installed my ECE quick ratio box. My fluid kept foaming and the power assist just wasn't there. I tried bleeding it several times and even flushed the system more than once which didn't help. Once I bolted on a new pump she was good to go.
01-20-2007, 08:29 AM | #12 |
laying low
These pumps aren't all that expensive either. Seems like around $45 or so.
[I jacked the front up and with the motor off I cycled the steering for a few minutes then fired it up and did the same.] Kevin the engine has to be running while turning the wheels lock to lock to bleed the air from system. Maybe give it more time and it might clear out.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
01-20-2007, 11:32 PM | #13 |
Well I bought a new pump today and also a new psi hose. I figure I have a new steering box that came with it and I already replaced the return hose so I will just put it all on in the morning and it should be good to go!
Thanks for the input. Kevin LFD Inc. |
01-20-2007, 11:38 PM | #14 |
blood type; Retumbo
did some of the old hose get in the pump and plug up the small screen in the pressure control valve?
I first bleed with engine off and front raised. then start engine and repeat. then do it again with the wheels on the ground and engine running. just make sure you dont go to full lock while turning the wheel. |
