Old 01-19-2007, 11:56 PM   #1
cjracing15
cjracing15's Avatar
Help on K-10 4.3 to 350 motor swap
I just found this board & I love it so far . I was wondering if somebody has done this swap? Any help will be much Appreciated. THANKS.
cjracing15 is offline   Reply With Quote
Old 01-20-2007, 01:08 AM   #2
beaterC10
Re: Help on K-10 4.3 to 350 motor swap
I have done this swap on a 86 2wd. You have to change:
motor mounts and frame stands
accel cable
trans cooling lines
A/C lines to the compressor
modify the engine harness to accomodate the different sensor locations
radiator and shroud
beaterC10 is offline   Reply With Quote
Old 01-20-2007, 03:33 PM   #3
kevinr1970
Try t ofind someone parting a similar year truck. Buy one if its cheap enough so you get everything.
2009 Honda Fit CfC (bsf 44.9 mpg)
2000 Tahoe Limited
1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below
1991 GMC CrewCab Dually 4x4, just going to fix things up for now
1982/1989 K5/GMC Jimmy 2wd
1987 GMC 1/2 ton swb 2wd Crew (sold)
kevinr1970 is offline   Reply With Quote
Old 01-21-2007, 10:23 AM   #4
cjracing15
cjracing15's Avatar
Thumbs up Re: Help on K-10 4.3 to 350 motor swap
Thanks for the replys. Any more ideas? Anyone? Thanks.
Old 01-22-2007, 05:08 PM   #5
toomanytoyz
Luv the Crewcabs
toomanytoyz's Avatar
ttt for You.................
Im looking at doing just the opposite, Maybe we can trade Out Mounts?
http://67-72chevytrucks.com/vboard/s...d.php?t=224293
Thanks, Rick
toomanytoyz is offline   Reply With Quote
