Old 01-20-2007, 12:20 AM   #1
bucket
bucket's Avatar
modifying 67 cab for 70 ac - is it worth it?
i have my 67 big window cab stripped, ready for the blaster. i was planning on cutting holes for ac and modifying firewall for brake and fuse box for use on my 70. now i'm wondering if i shouldn't just switch the dash for a later one since the ignition bezels are different. aren't ash trays different too?
its in real good shape for midwest but it does need some floor and cab corner work. i'm pretty good at welding but i'm beginning to wonder if i shouldn't start with a later ac cab. thoughts?
bucket is offline   Reply With Quote
Old 01-20-2007, 12:37 AM   #2
low'n slow
Too Dumb To Know Better
low'n slow's Avatar
Re: modifying 67 cab for 70 ac - is it worth it?
It is a lot easier to modify the existing dash for A/C than to swap in an A/C dash. JMHO
Good Luck
low'n slow is offline   Reply With Quote
Old 01-20-2007, 10:26 AM   #3
cooters
have you considered vintage air or some of the other aftermarket ac units. Alot less mods to the firewall required.
cooters is offline   Reply With Quote
Old 01-20-2007, 10:47 AM   #4
bucket
bucket's Avatar
already planning on vintage air. i wasn't going to modify that part of the firewall, just the part for the parking brake & fuse panel.
Old 01-20-2007, 10:55 AM   #5
Rokcrln
Rokcrln's Avatar
Modify what you have! That is half the fun of building these old trucks is that you can do all this with out melting plastic every where you turn
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
