Old 01-20-2007, 12:41 AM   #1
skokie
skokie's Avatar
Best way to clean power steering pump
I took my power steering pump off so I can get the brackets powder coated and figured I would clean up the pump as well. One of the hoses had a slit in it so the bottom has a buildup of power steering fluid. What can I use to get that off of there?
RIP to my son Dylan. 5/17/2002 - 8/18/2018
If you want to know more about rare forms of pediatric cancer or if you want to help fund pediatric cancer research, please check out the website for the non-profit I started.
https://slothforpedcancer.org
68 build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=223234
skokie is offline   Reply With Quote
Old 01-20-2007, 12:44 AM   #2
poorboy
poorboy's Avatar
Re: Best way to clean power steering pump
You can use a solvent tank or spray it off with parts cleaner and an air hose. Whatever method you use make sure you don't get any of the solvent or cleaner inside. I don't think the seals would like that.
poorboy is offline   Reply With Quote
Old 01-20-2007, 01:09 AM   #3
skokie
skokie's Avatar
I dont have a solvent take. What kind of parts cleaner could I use?
68 build thread
Old 01-20-2007, 01:11 AM   #4
GREASEMONKEY72
GREASEMONKEY72's Avatar
can spray it down with brake clean or carb clean and use a wire brush to scrub with
-steven
Alte Seele S.S.
"Allison" '72 C/10 LWB 350SB/TH350 - DD
PITBULL IS NOT A CRIME
GREASEMONKEY72 is offline   Reply With Quote
Old 01-20-2007, 01:17 AM   #5
skokie
skokie's Avatar
I have both of those. Will give it a try. Thanks much...
68 build thread
Old 01-20-2007, 01:20 AM   #6
GREASEMONKEY72
your welcome and goodluck
-steven
Alte Seele S.S.
