Old 01-20-2007, 12:42 AM   #1
64hotrod
64hotrod's Avatar
72' burb front end on a 64' stepside
Can I swap the front end off a 72' 1/2 ton two wheel drive suburban to a 64' truck frame? Reason is because the burb has 5 lug disk brakes, everything I want for my 64'. So... will it work? Thanks for any info, Steve
'64 c-10 short stepside
400 sb or 402 bb/ th400
rebuild,ongoing project,can of worms.
'71 c-20 long fleet for parts
'69 c-10 long rolling frame
'70 c-20 long fleet work truck
64hotrod is offline   Reply With Quote
Old 01-20-2007, 12:49 AM   #2
qksilver
Re: 72' burb front end on a 64' stepside
unbolt and then swap. It will bolt in with only having to drill a couple of new holes. If you are going to go the swap route go later model 73-up because the parts are cheaper and it rides better because of the rubber bushings, check out FAQ it goes into detail there
qksilver is offline   Reply With Quote
Old 01-20-2007, 01:05 AM   #3
64hotrod
64hotrod's Avatar
Cool! that's what i wanted to hear. thanks Qksilver
Old 01-20-2007, 07:06 PM   #4
Dr. Drop
You will find that you don't have to swap crossmembers to get 5lug disc brakes. Just change the upper and lower a-frames and spindles assembly.
then use the centerlink and inner and outer assembly and bolt it in. This will save you tons of time. While you are in there change the ball joints.
Dr. Drop is offline   Reply With Quote
