Old 01-20-2007, 02:06 AM   #1
tyjoja
73 manual to power steering conver.
I'm starting to fix up a 73 c10. It has manual steering. I bought a parts trk that has a power steering gear box and tilt wheel. Any tips on the process would be appreciated thanks
tyjoja is offline   Reply With Quote
Old 01-20-2007, 03:41 AM   #2
Russell
Professional Grade
Russell's Avatar
Re: 73 manual to power steering conver.
I'd imagine it is just a matter of taking your old steering box off the frame, swapping the new one on, then mounting the PS pump on the engine. Should be good to hit the road after that, though, I must say I sympathise with you in your efforts to get the pitman arm off :S
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-21-2007, 02:34 AM   #3
Slonaker
Insert Witty Text Here
Slonaker's Avatar
Rent, borrow, or buy a pitman arm puller. I tried (and broke) a couple of types of generic pullers trying to get mine off because the local auto parts stores said they didn't rent a pitman arm puller. I was returning a loaned generic puller to the store when I saw one on their list of loaner tools. That popped it right off. It helps to have the right tools.
Are you thinking of the 4WD ones, Russel? I hear they are tough to remove.
Slonaker
'86 Chevy C10 (Sold 04/19/13 )
Stock '01 Silverado
Slonaker is offline   Reply With Quote
Old 01-21-2007, 03:06 AM   #4
boxrodz
Until Seventy Times Seven
boxrodz's Avatar
Depending on how old your parts truck is, you may want to consider replacing the power steering pump and the hoses (at least, the seals) with new parts. I'd 'bably' flush out the unit, too. How's the rag joint? You could check the other steering components to see if they need replacing.
Ditto on what Slonaker suggested. The pitman arm remover makes quick work on removing the pitman arm. Or, you may decide to retain the pitman arm off of the parts truck and use a tie rod end puller.
boxRODz
1983 C10 SWB Fleetside
When two halves is gone, there's nuthin left. Two nothings is nuthin. That's mathematics son.
You can argue with me but you can't argue with figures. Two half nothings is a whole nuthin...
boxrodz is offline   Reply With Quote
Old 01-21-2007, 02:38 PM   #5
tyjoja
Thank you all for the threads, I had started taking off the old gear box and am down to the pittman arm and i'm stopped till I get a puller. A side track here: I'm trading out the steering column from my parts truck also and it is an automatic with the shifter on the column and my truck is a four on the floor, does anyone know where I can get the piece on the column that doesn't have the bracket for the shifter? Thanks again.
Old 01-21-2007, 10:56 PM   #6
Slonaker
Slonaker's Avatar
This look like it does what you want, but I don't know for sure.
http://www.speedwaymotors.com/p/2049...ift-Cover.html
Slonaker
Stock '01 Silverado
Old 01-21-2007, 11:16 PM   #7
tyjoja
Thanks a lot slonaker this looks like exactly what I need. I'm brand new to this, and don't know where to look for parts. I really appreciate it. tyjoja
Old 01-22-2007, 12:50 AM   #8
tkeduk8r
tkeduk8r's Avatar
I did this same thing on my 74... real easy... just swap out the box and I did the tie rod removal rather than the pitman arm... ONLY complaint i have had it that my steering wheel is now rotated about 30 degrees clockwise when I am going straight down the road... it is kind of annoying, but im going to wait till spring to try and fix... a crooked wheel was well worth the effort of putting the power steering in!!! between that and power brakes made the truck a total different experience to drive...
--Mike
63 C20 2WD, 230/SM420/4.11 73K
68 C30 dump truck, 327,SM425,4.56 66K original
68 C10 2WD SWB Stepper, 250/3-tree/3.73 66K.... Wifes
68 Buick Skylark Custom Conv., 350/TH400/2.56 In our family since '79
69 GMC 1500 SWB 2WD, 350/TH350/3.73 posi...
70 K10 SWB 4X4 4-sp,ps, pb, tilt, buckets, console, sliding back window (Need AC parts) WIP
72 Chevy K20 4x4 350/350/205/4.56 donor
72 Vette 350/M21/3.70 posi, triple black and super fast
84 Olds Cutlass Brougham 350/2004r/4.11 was Dad's
tkeduk8r is offline   Reply With Quote
Old 01-22-2007, 01:02 AM   #9
84 400
Sb 400 club
84 400's Avatar
mike you could barrow a sterring wheel puller and put the wheel on straight and that would slove your problem real quick
1984 chevy c10, built 400sb,.(SOLD)
77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363
1956 Willys Wagon (327 chevy) Project (Now Buick 225)
1980 Corvette L-48 4 speed
1992 Mustang GT built 5.0 5 speed
1985 C10 LWB Sold
1982 K10 SWB plow truck Parted out
1986 D30 M1028 fire brush truck Parted out
84 400 is offline   Reply With Quote
Old 01-22-2007, 11:18 AM   #10
tkeduk8r
tkeduk8r's Avatar
Yeah I was hoping the same thing, and I did pull the wheel back off to try to correct it, but the little slot in the column didnt provide enough adjustment. Good suggestion for others though... Im not usre how things got a little off when i did the swap, but i belivet he parts truck i got the pump off of had the same issue...i think... what ill prolly end up doing is pulling the pitman arm off and moving it over a tooth or two to correct it... who knows it may have been pulled off at one point before... OR if im lazy there are enough of those things (steering box) in the boneyards around here I could try to find a straight one...ohhhhh that leads me to another questiont o post... I know of a 80 Z28 that has its box yet... will that box swap over????
--Mike
