01-20-2007, 12:03 PM | #1 |
Gas Tank Install
I know this has been addressed before but I'm hoping for some definative info on how to bolt up the OEM style repop gas tanks. I'm working on my 72 K5 and cannot get this tank figured out. Should the bolts go through the straps and the flange on the tank? Should the flange on the tank be secured to the frame or hanging in the straps? BTW did I say that the repop gas tanks and straps for these things are terrible? Thanks for the help and pics would be very helpful.
01-20-2007, 12:58 PM | #2 |
Back in the sticks
Re: Gas Tank Install
No, the straps are bolted to the frame rails. The flange on the tank itself is just butted up against the frame. Put some anti-squeak rubber stuff inbetween the flange and the frame too. The straps go under the tank and bolt to one side or the other, thats really up to you. On mine, the s-hooks go into the passenger side and the bolts are on the drivers side. Good luck, Jeff.
1971 Cheyenne C-10 w/700R4 and Tuned Port Injection 1969 K5 Blazer w/Tuned Port 2010 2SS/RS Flaming Orange Camaro 2011 K1500 Suburban 2014 K1500 Pickup 2008 Nissan Altima? The wifes' hoopty |
01-20-2007, 01:29 PM | #3 |
Is that the OE setup? It just surprises me because the tank flange is touching the bolts on the drivers side. Do you have any pictures? Thanks again.
01-20-2007, 03:46 PM | #4 |
Back in the sticks
I don't have any pics here, sorry. That is the OE setup yes. You should be able to slide the tank one way or the other to get it more centered/where you like it. Just loosen the straps a little and move it to where you like.
01-20-2007, 04:29 PM | #5 |
The Blazer King
I did not even use my straps. The fit was so bad I cleaned up the stock ones and used them.
72 2wd Blazer. Its the superbichinest, megacoolinest, superflowinest. |
01-20-2007, 06:08 PM | #6 |
The LuvShack Garage
Poly tank pic's, but you get the idea
PS - Metal tank straps fit better
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T Last edited by LUV2XCLR8; 01-20-2007 at 06:08 PM. |
01-22-2007, 10:10 AM | #7 |
Thanks for all the info. I just decided to bolt the tank right to the frame rails without using the straps. The straps I got with the kit didn't even begin to fit and the PO had made a custom tank so I didn't have the old straps. There is extra reinforcement on the tank flange where the bolt holes are so I'm sure I won't have any problems with that setup.
02-23-2007, 09:56 PM | #8 |
nice pics thanks
02-24-2007, 07:19 AM | #9 |
The LuvShack Garage
Yvw
Owner/Op: "TN Classic Transport Carriers" The Toy: "Square Vette" 72 Hybrid Blazer Toy Barn: "LuvShack" 40 x 60 x 20 Shop Tow Piggy:"Maddy" 88 Silverado 3500 Hauler: "Feathers" 14 Aluma 8218T |
02-25-2007, 07:23 AM | #10 | |
The original tanks are NOT designed to be mounted that way, at the very least run an entire new (heavier) flange along with it and 'sandwich' the tank in between the heavy flange and the frame rail. Might just be me but I think it's a mistake to mount it that way. Find a way to either reproduce the factory mounting or another way to make it even better. Last edited by vtblazer; 02-25-2007 at 07:23 AM. |
02-25-2007, 07:59 AM | #11 |
I agree, 21 gallons of gas = 130lbs + weight of tank (25 lbs?). Can't you rebend the straps so that they fit? Notice that they don't fit up against the frame. One side does and the other uses the J hooks or longer bolts. My poly tank is actualy skinnier than my frame so I have to weld a plate onto the frame to make it have a narrower opening... whatever it takes is my motto...
The Garage: 1968 K-10 SWB - "Project Money Pit" 1996 Z-71 - "huntin rig" 1969 C-10 LWB (SOLD) "Project flip that truck or else" 1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie" My Garage Build "The 1,000 footer" |
02-25-2007, 09:15 AM | #12 |
Its lookin' like a Blazer!
Heres my thinking... The frame of your truck twists. Factory mounting allows the tank to float a bit. If you hard mount the tank it will twist with the frame. Couldn't be a good thing. You could always go get some thin sheet metal and make your own straps. Just bolt them up on both sides, you don't really need the hooks on the one end.
02-25-2007, 09:18 AM | #13 |
JMO but, I agree VT. Take your original ends and spot weld new straps to them. That is alot of weight.
I know you said the PO changed it out but you can find new straps, well old straps anyway. I work in a sheet metal shop and I can help you out with the stainless steel if need be. Even have a spot welder. Some trucks look cool dragging sparks, but I don't think it would work in this situation, Big Bang Theory and all that...
Semper Fi...Uncle Sam, you da man All parts offered to help are free, unless otherwise noted Dont try this stuff in my build thread, unless you have 55 years of mechanical OTJ training SAFETY FIRST AS usual, off topic They say your mind goes second, can't remember the first Jim |
02-26-2007, 12:34 PM | #14 |
Well, I think I'm going to try to modify the straps that came with the tank to run parallel to the frame, or rotated 90* from how they are intended to mount. The flange on the tank is thick enough that I don't need additional support against the frame rails, but I'm going to fab a way to run the straps as well. Thanks for the info guys.
02-26-2007, 06:05 PM | #15 |
Cereal Killer
i never have understood asking for advise and then arguing with common sense answers.
02-26-2007, 07:05 PM | #16 |
Not my problem, I try
02-26-2007, 07:36 PM | #17 |
02-26-2007, 07:55 PM | #18 |
Reminds me of the time I told a trucker he was dragging his chain, his response was "did ya every try pushing one"
same thing VT
